Manual BL has 4.7 gearing, lolyou can fix plumbing issues with duct tape too. If you’re planning on going 37s without 4.7 gearing it’s because of funds lol
Ok, agreed. If you have a BL manual and were guaranteed to go 37s and swap suspension I would have done the same thing and skipped squatch.Manual BL has 4.7 gearing, lol
Great! As i alluded, there are folks out there that find the intangibles have value beyond the strictly logical and functional, to take a page from your generation, not that i am that far behind you, you bought the 'Members Only' jacket as a young man in the 1980's for far more then it was worth from a functional or aesthetic comparison with other jackets because of your personal belief in the cachet of the badge, that it was better because it was less common/more expensive and conferred a form of increased status in your mind. Some people will agree with you and the Badlands fender sticker with the Sasquatch addition will bring in more dollars then without. For those folks, the badge on the jacket is the important thing, that it keeps them no more warm or dry is irrelevant to their perception that they are special for having paid more for the badge without getting a commensurate increase in utility.If everyone thinks like you then the production numbers of BL with Squatch will be really low compared to standard trim BLs. Thanks, my BL Squatch just gained equity.
Won't be financing. I don't make payments on my toys.
I am not buying a $2k 1" Lift, I am buying a Club Membership.
If I was still working 2 jobs as a 22 year old like when I bought my '85 4Runner off the floor, I might be more frugal. Probably not though since I traded in my 350 HP '77 Vette for it.
At 60 this summer , I am completely comfortable buying whatever trim I want.
And after I pass the warranty date , maybe 37s or 40s.
Value in having a Squatch over not having one.Great! As i alluded, there are folks out there that find the intangibles have value beyond the strictly logical and functional, to take a page from your generation, not that i am that far behind you, you bought the 'Members Only' jacket as a young man in the 1980's for far more then it was worth from a functional or aesthetic comparison with other jackets because of your personal belief in the cachet of the badge, that it was better because it was less common/more expensive and conferred a form of increased status in your mind. Some people will agree with you and the Badlands fender sticker with the Sasquatch addition will bring in more dollars then without. For those folks, the badge on the jacket is the important thing, that it keeps them no more warm or dry is irrelevant to their perception that they are special for having paid more for the badge without getting a commensurate increase in utility.
It is refreshing that you recognize and acknowledge that the value for you is 'being in the club'.
No Squatch 2.7What’s your Opinion on getting the Sasquatch package on a badlands model?
You should totally go SAS, OR you should avoid at all costs. Just depends...What’s your Opinion on getting the Sasquatch package on a badlands model?
I think you will find 4.46 and 35s won't have the upper power band torque.Even without the sasquatch(w/auto) it has 4.46 gears which are plenty fine to run 35's on a badlands without sas. You aren't going to notice it enough to worry about it.
Not nearly as big of a deal with a 10 speed auto that more easily keeps you in the power range easierI think you will find 4.46 and 35s won't have the upper power band torque.
As a real world example without doing the maths*,
My 85 4Runner had stock 4.10 and 31" 2.3 liter 5 speed (od)
When getting ready to re-gear and upside tires , I called Genuine Gear and told them what the oem setup was and that I was going to a 36" tire.
The guy I spoke with said hold on let me do the calculations, he came back and said I would need 5.29 for the 36s.
I did a test noting the engine rpms at 60 mph oem stock condition.
After the 5.29 and 36s , did the same 60 mph / rpm test.
It was only 50 rpm higher different than oem setup.
Even with 36s my 4Runner keeps in the Power Band running 5th gear. Literally runs faster than I feel comfortable driving it.
As a comparison, back in 1985 after I bought my 4Runner , I put 3" Lift and ran 12.50 x 15 x 33s on the oem 4.10 gears.
It struggled running 5th gear on any grade or pulling a small trailer with 2 dirt bikes on it. Summer trips from Dallas to Colorado sucked on the highway.
I am not getting the BL but I thought it was only 2500 to add it to the BL .I’ll disagree here and say for the $4000.00 you would be hard pressed to get:
-5 Bead lock capable wheels ~$1000
-5 35” tires mounted and balanced ~$1500
-wider finder flares ~$500
-lower gearing in auto ~$1000
-small lift to fit said larger tires ~$500
Now I know you could sell some of your takeoff flares, wheels and what not but you would also have invested your time into doing all the labor or paying someone to do the labor. Seems kind of a wash on that front to me.
YMMV
Seems like not so bad of a deal “if” you wanted 35’s and a small lift.
anyone who is planning on using a beadlock will buy a set after market. Ford is forcing the cost into the package where 99% will never beadlock a tire. Might as well get a nitrogen fill in the tires for that extra $1000 cost over the stockers from the factory. The cost difference in the tires is what you need to look at, not the entire cost. Maybe $400 there and you get the hybrid mud tires when a lot of people will be better off with the KO2's.
Don't need the flares if you don't get the oversized tires
The gearing to the ground in a BL automatic is the same (~5% lower gearing, but ~5% smaller circumference tire than the Sasquatch with 4.70 gears, so a wash)
If you are going to life to get larger tires, why waste your money on buying the Sasquatch ones anyway? Even selling them is going to be a net loss, but I guess you could use those flares, but you would have paid $4000 for them and thrown away the rest of the stuff with a lift and a set of wheels/tires.
I don't know how much your time is worth, but if I had spent as much time counting pennies & trolling other people's purchase decisions as you, I would already have an opportunity cost (net loss) equivalent to the value of the Sasquatch package on a BL. And yes, getting the lowest gearing is a benefit for resale or future upgrades.Mansquatch vs BL with the optional wheels and tires will have the following differences; under an inch more ground clearance and a slightly taller and wider tire on a 0.5" wider rim (both are beadlock capable)
For you it seems <1" of ground clearance and $450 of tire cost difference (for all 5 combined) is worth the $2400 (plus tax and any financing charges on that amount if you don't pay in cash for the truck). Congratulatons! You just bought a $2000 1" lift kit! While you believe that will come back to you in resale value, I am thinking that is a tad too optimistic on your part, but stranger things have happened.
Despite 4.10’s being perfectly fine in development of the Bronco. And still being perfectly fine for all generations of F-150 Raptors even the latest with factory 37’sI think you will find 4.46 and 35s won't have the upper power band torque.
