SoonerNatx
Todd
Austin
'23 Bronco 4d 2.7 MIC
Had a similar situation years ago with a truck. Was on a toll road and a truck in front of me started losing his load of plastic bags of paper trash. Thought I swerved enough to avoid them but apparently one caught underneath and was stuck at the catalytic converter. Someone pulled up next to and pointed for me to pull over. No sooner then I got out of the truck, the undercarriage and engine bay were ablaze.
Axle Roads
Northern California (Gold Country)
2022 Bronco Badlands 2 Door, 2017 Nissan Frontier
Super scary! I’m so sorry to see that, and I’m very glad no one was hurt. I hope insurance treats you well. At the very least this gives a you a chance to change any model/trim/color options you may have wished you had went with the first time. Best of luck to you.
CaptMorgan
George
Ohio
Ram 1500
Been a certified fire investigator 20yrs. I'm pretty sure.
Then you should know that, without examining it, you can’t make a blanket statement like that.
ADK23
Don
NY
2023 Bronco 2 Dr
Please update if or when a cause is determined. Glad nobody got hurt
So this happened yesterday. Had just hit 25k miles on my '22 Badlands Bronco. Pulled into a rest area. Shut the vehicle off. Was gone at most 5 minutes and walked out to see black smoke pouring out of the hood. Fire was contained to the engine bay until the flames were so high the hard top caught fire, and the rest is history. Fire department was unable to determine cause. Up until this point, I have had zero issues with the vehicle. Sad day...
Update: it's a 2.7 Auto
Happy to see that you were not hurt. Of course, very sad to see your beautiful bronco go up in flames. I’m curious if you had any sort of aftermarket electrical lighting or anything like that or was this purely a stock vehicle? Please keep us in the loop when you find the cause. Hope you get a new bronco soon.
lakesinai
Charleston SC
How sad! Gives new meaning to the word "total loss!" I hope you find out "why?"!
c_hack
Cameron
2011 Ford F-150 FX2
Ugh well I guess I will be parking at the end of the driveway until further notice.
Two new fears unlocked today.
Avoid parking in garage to prevent spontaneously combusting Bronco fires burning the house down, or park in garage to avoid bird nest Bronco fires. Pick your poison? 🔥💥🦅
Jdyount
Kansas
2021 Badlands
Are they fine staying in the vehicle year round, even in summer heat? Asking from Texas where temps regularly stay above 100F and the vehicle temps are somewhere between hell and death (but not quite as hot as OP’s ☹)
Yes, most fire extinguishers are going to be rated for extreme temps. Make sure you check out the ratings. There are also other options like Element 50 extinguishers.
MadMan4BamaNATL
Ray
Atlanta
2.7 auto... yeah, not sure how anyone could pinpoint the cause in that mess.
Damn that bites!
Hey man, in one of your pics I can see a rats nest of wires that are all crossed up and bundled. I am sure it’s your lights.
I also have Baja Design lights as you do that I installed.
Who did your installation? Also, what wiring harness is that?
I fear what the adjuster is going to do to you in this case, so it’ll likely be a battle.
Lesson for all readers; wires should be folded, not jumbled, as it can create magnetic issues which concentrate energy. Also, if your wires are near a heat source, things like this can happen like under extreme heat during a long road trip or in the summer. Finally, if you did your own wiring, check it from time to time.
Wires should be zip tied to secure somewhat tightly when you have excess and of course keep away from the heat and always ground your connections.
Did you connect to Upfitter switches and did you use heat shrinks or weather connection covers? I’d say that’s likely the source.
If this were Ford‘s fault, we’d see a lot of them and we don’t. Modern car inspection and QC processes are far too robust for things like this to squeeze through.
Let’s all just learn the lesson from wiring and connecting things to our batteries to be as cautious as possible.
Wish you the best man.
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
OP, was the engine running or was it off? If it was off, I doubt it was electrical. Pavement on fire would seem to indicate some flammable liquid, unless it's molten plastic or other composite materials.
KRoyal080
Keith
Cincinnati
Engine was shutoff. Everything that was burning on the ground were molten parts of the vehicle.
sjudas
CT
Wow. That is crazy. Sorry.
tokyo
Utah / Japan
siennavenzasparkXDfit
So sorry OP for your loss and echo the sentiment that glad no one was hurt.
