I had the knee panel down yesterday when I was installing my first mod, the Autostop Eliminator.
The connector for the TBC is present even without the tow package
here is the BCM/Interior Fuse Panel. Interestingly enough a Secuicode keypad Code card was clipped to this, even though you can't get a wired keypad on the Bronco and the RF one doesn't use the code. Next time I have Forscan connected I'll check to see if the code in the BCM matches this card:
And up above the kick panel where C105/C201 are supposed to be. Only connectors I see are these two plugged into the DCU module. Maybe those connectors are behind the speaker?
