- Jul 16, 2020
- 28
- 754
- 2,947
- Goshen, Ky
- 05 Mustang, 05 F150, 08 Expedition EL, 21 Bronco
- Badlands
I'm about 99% sure.
First, I've worked in Ford assembly plants for the last 30 years, both as an assembler and in maintenance. There's no way any engineer would set up the assembly line in such a way as to require the removal of the bumper after the fact in order to put on the tow bracket. That doesn't make any sense.
So, I acquired a copy of my errorproofing report and went through all 1803 EP stations looking for where in the process the tow bracket is added, knowing full well that process probably has a tool that reports proper torque was applied. I found that the tow bracket appears to be attached to the frame while the frame/engine/chassis is built up on chassis line 1.
So....for all the folks wondering if you're waiting for your ride to go through the MOD center for the tow package, you're not. I figured yall would want to know.
