Towing capacity??
BONESTOCK
MA
'94 Lightning w/TKO swap, '04 Procharged Mach 1, '13 F150 RCSB 5.0L, '61 Falcon
Lol it happens! If only we could go back to the days of expecting trucks to only weigh 3500lbs... hell, modern performance cars have trouble meeting that weight!
LOL!! It's all tha airbags, camera's, wiring that add all that freakin weight.
TeocaliMG
Matthew
Dearborn Michigarn
1987 f-250 6.9 idi diesel, 2004 jeep liberty sport
I'm going to guess towing will be in-between 3500 and 4500. enough to edge out the wrangler but not compromise the soft suspension for good off road ride/handling/articulation. Ford probably assumes (rightfully so) that most customers who need to tow significantly more than that will get a truck anyway, or already have one. I know I certainly would prefer driving my truck if I needed to tow more than that.
3crows
J
Wichita, KS
Wrangler Rubicon, Toyota Tacoma
Lifted, high clearance vehicles with generally a more narrow track and shorter wheelbase needed for real off-road maneuverability and duty generally make poor tow vehicles. It is not a matter of horsepower strictly speaking but one of stability. If the Bronco is going to quote Ford go toe to toe with the Wrangler off-road then I doubt it could have a significantly higher tow capacity without severely compromising off-road capability. It is physics, not magic.
The Gladiator has a higher tow limit as I suspect maybe a Bronco PU would have, if it ever really come to fruition. Nothing but vaporware so far and big talk by the Blue Oval.
I think some of you guys just really want a big PU truck with Bronco decals on it. There are already plenty of good tow vehicles available, what there is not plenty of is truly off-road capable vehicle, the Wrangler being the only one left. Well, the Tacoma is pretty capable as is the 4Runner but last I checked, their tops do not come off nor do the doors.
My 14yo Tacoma does not break a sweat towing our BW Outrage, both truck and boat loaded to the gills. Made many long distance, cross country tows.
Nickp
Nick
Phoenix
2010 WRANGLER 4 DOOR MT
BUT I WANT MAH V8 AND I WANNA TOW AND GO OFF ROAD.
^People who don’t understand towing wanting the “full size” bronco.
Jake_zx2
Jake_zx2
Jake
2018 Mustang GT
  • Thread starter
  • Thread Starter
  • #20
Exactly. If I wanted a pickup, I'd buy a pickup. I don't understand why that's so difficult to understand.
But really, Ford may SAY that the Bronco is going to be a direct jeep competitor, but we know it's going to be wider, will likely be longer, and ultimately will not be as off-road capable. Seriously, recent pictures are showing that there's a pretty good chance it's going to be IFS... that screams "compromise"
But really, the 4-runner is plenty off-road capable, and has a significantly higher tow rating than the Jeep (and will likely be closer in size and weight to the Bronco). There's no reason the Bronco can't be off-road capable AND have a fairly decent tow rating in base guise. For the guys who want a pure off-roader, maybe there'll be a package that is more off-road oriented and have a tow rating of 100lbs
BUT I WANT MAH ESCAPE WITH A VERTICAL WINDSHIELD AND A LIFT KIT
Seriously, if you're going to say dumb shit that contributes absolutely nothing, leave it for your own threads
Stampede.Offroad
SD
junk
But really, Ford may SAY that the Bronco is going to be a direct jeep competitor, but we know it's going to be wider, will likely be longer, and ultimately will not be as off-road capable..
Ford has never said that. The dealer meeting in NV in Nov last year had a PowerPoint slide that just said "beat Jeep" -- we don't know if that means sales volume, off road capability, number of paint colors offered, road manners etc etc etc because _Ford_ has never told us what purpose or goal they have for the Bronco.
The 4-door will probably be shorter than the Wrangler-U by 6" in the wheelbase and 1" narrower track based on the dimensions of the Ranger/Everest and the mules we've seen. Only the body width is likely to be greater -- and that's no surprise, a small car has a wider body than the Wrangler, and the Wrangler itself has gotten wider and wider over the generations. Even the EB would be wider.
As for towing that will come down to the rigidness of the chassis, which Bronco may very well be superior in because it will be shared with a high payload pickup, and the suspension ... we don't know a **** thing about.
3crows
J
Wichita, KS
Do y'all remember the Liberty. It was available with a common rail diesel for a short time. My wife had a gas one, my sister the CRD. Both had 5,000 pound tow ratings. My wife put 300,000 trouble free miles on it and yes, it got to tow the 4,000 pound BW a number of times. The boat would push it around pretty badly. It had the power but not enough wheelbase and width. But it had plenty of power. We had an original Ford Exploder, 5,000 pound tow rating and it exploded at 156,000 miles. But it was much more stable towing the boat. When you start lifting vehicles, expect to loose towing stability and braking (in general).
Ford has said that the Bronco would have capabilities and features similar to the Wrangler, but you are right, that leaves a huge gulf of empty space in which to interpret the meaning of such things as "beat" the Wrangler.
You know, for us Wrangler folks, it is top off season, doors off too. Bikini top on, air-conditioner blasting and the stereo going and mud and dirt flying. You can keep the Raptors and hulking V8s full size vehicles and all that and turn green with jealousy when a mud covered Wrangler, top down, lifted, loaded with bikes and kayaks across the roll cage pulls up beside you and you know he/she has been where you cannot go and had more fun going and coming topless and doorless than you would even if you could. That is what sells Wranglers so if Ford intends to "beat" the Wrangler they may want to consider the successful recipe.
Stampede.Offroad
SD
junk
Ford has said that the Bronco would have capabilities and features similar to the Wrangler .... .
No, they haven't. Not even remotely. Ford has said absolutely nothing about what the intend the Bronco to compete with. Nothing about what it is supposed to be capable of, beyond meaningles marketing fluff (i.e. "way beyond the city").
I wish they would. It's ******* annoying to not know what their target is for capability or competition.
The public and many "journalists" have presumed Ford's intention is for the Bronco to compete with the Wrangler as it once did with the CJ. But Ford has never said that or anything even remotely resembling it. Unless you think "not wimpy" = "will compete with the most off road capable production vehicle currently available".
Jake_zx2
Jake_zx2
Jake
2018 Mustang GT
  • Thread starter
  • Thread Starter
  • #24
I didn't think so, but wasn't going to harp on some he-said-she-said. I'd rather just give him the benefit of the doubt and get my point across
BroncoMike
Upper Norwegia
'71 Bronco, '02 Excursion
"For Jeep, it’s all about rock crawling in Moab, but our premise is completely different," - Jim Farley
Sounds like an anti-Wrangler.
What Ford has said officially and publicly is very little. Nothing about "capabilities". Nothing about "features".
"Beat the Wrangler"? Please show me where Ford said that.
Broncosaur
Bob
Connecticut
Right from the ford website.
BRONCO RIDES AGAIN
Way back in 1966, Ford introduced its original SUV and cut a trail to the great outdoors that would be followed by generations of Americans. And now, Bronco is coming back, strapped with thrilling power and go-anywhere capability, uniquely equipped to carry true adventure seekers deep into the wild and untamed places their souls long to be.
frinesi2
MD
'96/'97 Jeep Grand Cherokee 4.0L, '92 Mitsubishi Pajero 2.5TD, '15 VW Golf TDI
Does a mid sized SUV that weighs about 3500 pounds, has a super short wheel base and tows close to twice it's weight currently even exist?
Talk about tail wagging the dog.
3,500 lb curb weight? No, but Grand Cherokee, VW Touareg, and Porsche Cayenne are 2-row, shortish wheelbase SUVs that tow 7500+ lbs
ETA: didn't realize this thread was so old, but still ...
ChrispyKC
Kansas City
2018 Expedition Platinum, 2016 Escape SE, 2015 Jeep Wrangler 2DR Sahara
Does anyone have any idea or educated guesses what the towing capacity for the Bronco will be like? The Wrangler's towing capacity is pretty abysmal at 3000lbs, and if it's that low, I won't bother waiting and I'll just go get a Ranger. But considering it's based on the ranger's platform which is rated for 7500lbs, and it's been spotted benchmarking with the Toyota 4Runner, which is rated at 5000lbs (relatively close to the Tacoma at 6800lbs), so I (optimistically) don't think a 6000lb or so towing capacity is too terribly unrealistic. I just really want to be able to tow my Mustang with a full truck and not have to worry about it. Would also love to tow my other car along with the Mustang, but I know that's a bit much to ask for
What do yall think?
My take?
5000 lb for the two door 6500 for the four door. The four door will have the wheelbase advantage to raise the capacity. Both vehicles will have trans oil coolers and and larger capacity radiators with the tow package. Manual trans will drop both towing capacities by at least 500 lbs.
BroncoBuyer
Phoenix AZ
GMC
we have a grand Cherokee, trust me it drives like a full sized Tahoe. They are not the small mid sized SUV’s they used to be from early 90’s till the 2004 models. Ours has the hemi 5.7 and 4x4 and it’s MAX towing ability is only 7200 pounds, weighs almost 6,000 pounds and off roads like crap compared to our old 2004 overland with solid axles.
If the Bronco is a bloated tank of an suv like the Grand Cherokee I’m out.
I expect it to have nothing more than 5,000 for a towing capacity.
we get only about 13 mpg too wich sucks.
Stampede.Offroad
SD
junk
...Manual trans will drop both towing capacities by at least 500 lbs.
Why?
The MTI550 can handle over 20k lb. It looks like it was designed to be suitable for a Superduty Tremor too.
It makes sense for the Wrangler/Gladiator, whose 6sp manual can only take 272ftlb of torque.
Thread starter Similar threads Forum Replies Date
General Bronco Topics 8
Similar threads
Viability towing vehicle?
Similar threads
