Odd spare tire
Jrye22
Jon
New Jersey
2019 ranger lariat
Vehicle Showcase
while checking my manufacture date on the truck I noted that my spare is a 17inch rim according to the sticker and a different size tire then stock. I went with the 18 inch rims and haven’t actually looked at my spare yet but hopefully it will be a match of some kind even though the rim is smaller.
Randy2400h
Randy
2019 Ford Ranger Lariat Sport FX4, 2015 Ford Edge Sport
Vehicle Showcase
Yeah, Oops! I made the same mistake. I ordered a set of 5 tires (275/65-18s) for my stock 18” wheels. And come to find out that the spare wheel is a 17”. Now I have to head back to the tire shop again and change out the spare tire with a 275/70-17. Very close in size.
Dan
Dan
USA ILLINOIS
2019 Ranger CrewCab 4x4 301A
my guess is the spare rim is not the same and probably steel?
Randy2400h
Randy
Vehicle Showcase
Yes it is. And that’s what I want. Any kind of alloy rim with a finish on it will be destroyed by all the road grime. I looked to see if I could replace it with a steel 18” rim but no luck, so I’ll just stick with the 17” wheel and a full size tire. Since I went up in tire size and haven’t modified the crash bars it was very important that I keep the same offset for the spare wheel. Imagine a scenario where you puncture one of the front tires on a rocky trail, replace it with the spare wheel, and then pop the spare because it was rubbing in the front wheel well (due to the different offset). You’d have a really bad day.
pannwfn
Paul
Mississippi
2005 fx4 level II
Already been there done this it's on another post its a 265 65 r 17 on a steel wheel from a base XL.
Rinn69
N. Central Iowa
2019 Ranger Lariat SuperCrew 4x4 Lightning Blue
Occupation
Retired USAF MSgt
Vehicle Showcase
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Occupation
Retired Engineer
Not mine, its a 17" aluminum temp spare rim with a Hankook Ht on it. My rims at 18" with Hankook AT M,s
I sense a trend....:)
My four tires are the sport version 17" Dueler A/T's but the spare is a 16" Hankook 255/70. The Rim looks like your's (only cleaner - lol). Maybe the spares are all mounted on 1" smaller diameter wheels?
SemperVee
Dar
Olympia WA
2022 F150 LARIAT. 2019 Ranger XLT Traded in.
Vehicle Showcase
My 4wheels and tires are 265/60 X 18 but the spare is 255/70/16? The XLT is suppose to come with a 17 inch tire? Is it just mine or you too missing real spare size just in case?
doug910
Doug
Detroit, MI
'19 Ranger, '02 BMW 540i
Occupation
Engineer
Your spare uses a 16 in wheel because it's much cheaper to use a 16 in steel wheel as opposed to the 18 in aluminum wheel.
Wheel diameter is not significant, only outer tire diameter. A 265/60/18 is a 30.5" outer diameter tire whereas 255/70/16 is a 30.2" outer diameter tire, which is a close enough approximation.
Rinn69
N. Central Iowa
Occupation
Retired USAF MSgt
Vehicle Showcase
My spare tire has an aluminum wheel.
SemperVee
Dar
Olympia WA
Vehicle Showcase
I would have preferred the same size wheel but I had pushed the purchase price so low they were not giving into anything else I had wanted to "Fix"... i got my XLT Sport with all the options for basically 35K +T/L
