Towing Package: worth it or no?
RedHotFuzz
2022 Bronco Black Diamond 4D
Last question before I place my order (Black Diamond) this week: is the common consensus that the Towing Capability is not worth the $600 asking price as it is merely a hitch and a wiring harness? No transmission cooler/etc. that you may get with other vehicles' tow packages?
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I’m not sure it matters as much what you get with other vehicles (the Bronco probably doesn’t need a trans cooler or larger radiator for the 3.5k rating). To me it’s just expensive for a basic hitch and harness. Hitch should be less than $150 aftermarket and a good plug in harness and factory “replica” mount and 5/7 pin connector about $100-$120. I can install it myself, if you can’t , figure $150 for labor. That’s about 40% off for aftermarket. I will also hopefully add a class III hitch as well for about the same $.
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
It also adds another recovery point to the rear of the vehicle. So for me, that and the wiring make it worth it.
SnowBronco
Canada
I just took mine off my order. Figured there's no point if the hitch is only rated for 3500lbs. I don't know if they will up the rating to a class3 or 5000lbs... But if they do I just wasted 600 to have to change it out again anyways... So I'll just wait a bit and see. Besides I'll get ford to install one at some point depending on what trailer I eventually buy, so that'll look after the whole package and wiring that may have been included originally.
Erock
US
2018 F150 Alpine edition
Place to attach a winch to.
jjack50
Jack
Temple, NH
The receiver with the factory hitch is already a 2” unit. I don’t know what more you’d get with an aftermarket class III hitch.
RedHotFuzz
RedHotFuzz
Right, I know the advantage of having a hitch receiver (which I plan to get regardless). The question is whether the factory option is worth the $600 or if an equivalent (or better) aftermarket solution will be available for significantly less.
Mattwings
Matthew
Northville, MI
I would ask the winch manufacturer, but class II , 3500lb capacity receiver is maybe a bit light for even a 5k lb. winch. Adding a snatch block to pull the big Bronco would definitely stress the capacity.
Mattwings
Matthew
Northville, MI
I think the trailer brake wiring was covered in one of the other trailering threads, my boat has surge brakes, so not an issue for me (this I don’t commit the answer to memory 🤔).
Erock
US
Was only answering about the additional recovery point... but yeah, I know what ya mean about capacity
