Traction Board Mounting Brackets by Pura Vida Offroad
mosdepo
Oregon
I don't see any specs on the spacing between mounting holes, however, they look very similar to ARB and MaxTrax so I believe they'll fit fine.
Here's the specs the board mounts support - "The bracket supports board hole widths at either 4.2" or 10.63" and board hole lengths between 34" and 41""
Awesome. Ordering now!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I just decided I need this to mount fishing poles and stash recovery gear - but, then I realized - mine is an early 2021 that doesn’t have the threaded mount points on the D-pillar. I’m assuming drilling through that boron steel is more difficult than it’s worth…
UtahBrandon
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I’ve seen a few people that were drilling through the roll bar to install the nutserts so I’d say it’s definitely doable. I’ll have to get some measurements for placement and share that. I’ll also see if I can find the forum thread where they were discussing it.
redone17
Cold Spring, NY
Thanks! A search was my next order of business. Any info you can share is much appreciated.
