- Ed
- Jul 31, 2020
- 7
- 204
- 471
- Sacramento
- VW Atlas, F-150 Tremor
- Badlands
Hello B6G Hivemind, I invoke thy collective wisdom...
Purpose of Bronco: DD + family adventuremobile in the CA Sierra. (Family is 2 parental units + 2 hyperactive squeaky wheels under 5). Explore and camp where there are less people
Experience with Bronco: Las Vegas Off Roadeo, BL Mid SAS
Pep peeves: missing buttons (ie no stas-disco), weird bezels (8 in)
Commute: 46 mi roundtrip. Highway speeds in, 50/50 highway/surface streets on the way back
Current spec: BL 2.7 Mid MIC Tow WheelUpgrade
MPG difference between Base BL vs BL Sas is +1 mpg Highway for the non-Sas version.
Pros for Each
Sas gives you that really nice stance, better ground clearance. Better axles
Lux setup would give heated steering wheel (nice to have on 32 degree morning to work), better sound system, ACC, garage opener
Cons for each
Sas set up should suck more gas. more difficult for the littles to get in. longer breaking distance?
Lux setup has more tech to break. More cost to fix windshield when radar need to be recalibrated for worn tires (happened with our Atlas)
First world problem: For the stated use case what makes most sense BL Lux Non-Sas vs BL High SAS
I appreciate your input, thanks!
Pros for Each
Cons for each
