Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
These failures are surprising to me. Outside of any beef with how 74 conducts themselves, these tie rod mounts seem much beefier than the stocks and people on bigger tires arent ripping stock uprights like this. And the stocks are cast vs this billet 7075. Makes me wonder if it is a bad heat treat, bad design geo with a stress concentrator, or a install error that isn’t immediately obvious.
i'm leaning towards install error at the moment
SierraBronco
2022 Bronco
Just out of curiosity-with the information provided so far, what is swaying you in that direction? Hard to tell zooming in but maybe the heim was rubbing on the top misalignment?
Ford Bronco Trail Militia is going there: 74Weld vs Werewolf Portals 74716668-6731-4A92-9A8F-1684BEE56F27
Lcubed
l
UsA
the previously shown toyota installs and the unknown quals of the installation folks.
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
Excellent point. If the rod end is hitting max range that would impart a large bending load on the upright.
SierraBronco
2022 Bronco
Gotcha. We mostly seemed to be in agreement that the big washer on the bottom of the Toyotas seemed peculiar, but so far every toyota has been like that. Doesn’t mean anything of course-maybe 74w is just that bad at their job that they send the wrong washers with every toyota kit and only had the one crack. Hard to say on that. On the tierod pictured here the washers look to be seated properly. I replaced a steering rack and tierod on the trail with TM guys-they seemed to know what they were doing and noticed that the bolt the mechanic installed was cut off, exonerating 74w from blame for another failed rack. Good observation.
Just my observations. I don’t know what the problem is and seems how I have a set of these portals on a daily driver (might be a dedicated trail rig if these issues continue) I would much prefer it to be an installation issue.
Razorback
Bill
Dallas
Lincoln MKX
While not a direct cause, could point to other issues of install; where's the rest of the bolt that should extend past the nut?
krazykevin
Kevin
Houston
GX470 / Lotus Elise
Ford Bronco Trail Militia is going there: 74Weld vs Werewolf Portals 1739301356875-lt
To me this does look like the rod end housing might be contacting the upper spacer/washer (it looks like a witness mark/ring). If this is happening it would create a large bending moment on the steering tab on the knuckle.
SierraBronco
2022 Bronco
This is why I had my shit installed "professionally". :rolleyes:
74w does have a stringent vetting process for their authorized vendors by **checks notes** knowing they have had an race car at some point.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Didn't realize this was not known by people in this thread.
https://www.bronco6g.com/forum/threads/icon-tie-rod-ends.74907/page-2#post-1948159
The FabTech tie rod is not “better than Icon” with a lifted truck if the heim joint bottoms out at full droop, which it does with Fox coilovers (3.5in), and probably any lift requiring aftermarket UCAs. The heim joint does not articulate as far as the stock or Icon tie rod. I do prefer a heim joint, but not if it bottoms out and eventually grenades.
GreyZ
From some angles the 74 portals also look like they may shift the tie rod attachement point lower, which would make this bottom out issues worse. The 4wp coilovers are right at the length limit as it is.
SierraBronco
2022 Bronco
That’s actually not the first time I’ve heard that on the tie rod attachment point. From people much more experienced and knowledgeable than myself.
