Seano1685
Sean
Ford Bronco
in stock soon. We are working on it. If you want, you can order some of the last few standard wind deflector models, then upgrade the deflector to the 40" once they are in stock and ready to ship.
I might do this, but to confirm you’ll sell the light bar cut out wind deflector separately that can be used swap out the standard wind deflector?
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
got my rack installed yesterday,took me 3 hrs to install (between service call outs,that'll teach me for doing it after hrs at work lol) it looks great and is very sturdy great job Trailrax,only change i could suggest is the lower bolts for the pakrax should be black not silver.
TrailRax
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Thanks for the feedback! We are looking into it, the stainless steel may not look pretty but the availability and cost of Black hex bolts are tough. We want to stick to the hex on the Pak rax as we advertise them to be removable and hex hardware allows for a wide range of tools to wrench on versus an Allen key that can be lost easily.
This is something we will absolutely look into!
JMV123
Wyoming
2017 Ford F350/2015 Subaru
Any method of attaching bike racks to the TrailRax rack? Currently have some Thule racks and was wondering if there is a way of attachmnt. Thanks in advance!
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Most if not all Bike racks should work on the TRMR Rack. Most use a clamp style which you can clamp to the extrusions. If not, others use a T track in which you should be able to bolt to your extrusion.
JMV123
Wyoming
Thanks and what are the dimensions for those extrusions?
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
They are fractional so they use a 1x2" profile and 1/4-20 hardware works best.
JMV123
Wyoming
Perfect and thanks for your prompt replies! Looks like a great product. Just waiting on my Bronco like many others!
Tilzbow
NV
GM Sierra Diesel Pick Up
Will the Pak Rax hold two 3 gallon Rotopax side by side on each side of the 2-door Bronco? Total would be 12 gallons with 6 gallons per side. I’m asking because I already have the gas cans and don’t want to spend more on new cans.
Dimensions
16 L x 15 W x 4 1/2 H
Possibly, we have never done 2x 3 gallons mounted side by side to one another. It should work but we cannot say it will fall together perfectly like a 4 gallon would. So yes you may have to drill holes into the mounting plate.
Good news! Got the system installed and I can confirm the Pak Rax will hold two 3 gallon Rotopax! Rotopax mounts can be installed either horizontal or vertical. I like the vertical install (second picture) better since it keeps the fuel packs closer together.
Ford Bronco TrailRax Modular Roof Rack For Your Bronco 55D9F8B6-AE8E-40B8-92EF-1C490ADA2A28
Ford Bronco TrailRax Modular Roof Rack For Your Bronco 119797F4-F636-4990-BF83-FC0F285FB16F
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Looking good! try to leave them horizontal, it will offer a bit more stability in the mounting plate.
David-AK
Maryland
www.instagram.com
Audi Q7, Bronco Badsquatch
@TrailRax Could you confirm the full rack is one piece, not a rear section that can be used independently?
Your description of the rear rack leads me to believe there might be options:
"Our TrailRax Ford Bronco Roof Rack is a great option for the all-out overlanders as well as the entry-level overlanders. This rack gives the end-user the ability to upgrade or add on to their roof rack as they need."
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
We can confirm, the side panels are one piece for the best stability, structure, and capacity possible that is tested through a CAD software and tested in real world applications. Most rack companies will not go this length to test weight.
we state you can add as needed with our accessories coming out and pak rax.
2PT7
Alan
San Antonio, Tx
For those planning on tent installs fear not, the TRMR handles your overland needs with ease.. Took it out to Davis for testing last weekend!
Ford Bronco TrailRax Modular Roof Rack For Your Bronco DSC01473
what kind of tent is that?
