Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D)
Adam
Kansas City, MO
2014 Ford F150
Recently received the raised lid Tuffy enclosure (VM2DZ-78115A00-D). All together was pretty impressed with the system. I really like how it has the gas shocks to help hold the lid open. I’m sure this will allow better access if items are stored further back in the cargo area. Also really likes how the walls have a MOLLE system to help further organize. The D-rings on the lid are nice touch to strap gear down or use a cargo net to hold items. I can see so many possibilities with this set up while keeping items secure if you have the doors or top off!
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) EE047B51-8AD2-4954-A5D8-14D3815860EE
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 83AB77F8-E379-4F6F-A450-2CD73DD95D3F
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) FD2B58A0-0B5F-499D-A7AC-10E06EF3A157
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) A5CA72B5-D53B-4EC6-80FD-048DDEBEEDB2
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 5E8917BD-D4A7-4D7F-9468-19AF46D00EE4
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 92A5C15C-B0BE-404E-8899-C69CE112A81C
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 75C232E4-7D25-4846-8AF7-293563BD9C2D
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 042BE2C5-3868-4DB8-8087-975804C9EC0D
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) DA36BECE-595F-41BC-968C-8DE6C83D1F6B
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 84806573-051A-42DB-ABDB-135B193705AD
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 777660B4-F99A-4B3D-9A6E-037110FDE551
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 0C86AE1C-E2AD-406A-AC67-91E50A1899CC
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 7BEB7D0A-66D4-4BDE-8EE1-5B9AEB284DD0
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) 826E38E9-34C7-4359-8C88-A52B59835DD3
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) CB5DA87D-E554-428F-ADDA-469012D605EF
mynameismyles657
Myles
Charlotte, NC
2017 GTI
I’ve been looking at either this or the regular enclosure to keep my camera gear in if I ever need to run into the gas station.
how securely does the lid close on this one?
TheWanderingBrewer
Adam
Kansas City, MO
2014 Ford F150
If you take a look at this pic there is a L shaped bracket that pivots into the rack to secure it(there is one on both sides). They have enough tension that they won’t rattle open going dow the road. There isn’t a lock or anything.
TheWanderingBrewer
Adam
Kansas City, MO
2014 Ford F150
Been eyeing this since the overland concept build came out. How substantial does it feel when assembled? Any specs on load capacity for the lid?
Instructions say 50lbs. But I honestly think they are shooting that a little low for safety reasons.
Chrism81
chris
connecticut
Mazda
Ford Bronco Tuffy Deluxe Cargo Area Enclosure with a Raised Lid (VM2DZ-78115A00-D) C7D7924F-3D51-4495-BF0B-C2F21FB3AD62
when did this one pop up. I have only seen the fixed lid one. Also, is this for the 2 or 4 door and what are the internal dimensions? Looks nice
TheWanderingBrewer
Adam
Kansas City, MO
2014 Ford F150
It’s been in the accessory catalog for awhile. This is actually the one they used on the Overland build. The deluxe raised lid is for the 4 Door only.
Exterior size: 51.25W x 34.5D x 22.5H
Interior: 40.5W x 31.5Dish x 22H
Usable interior space is hard to judge without being installed.
Chrism81
chris
connecticut
Mazda
thanks, I must have missed it. Only saw the fixed one. Glad I saw this thread because I almost got the fixed one. I have the security drawer and trying to figure out if I can fit that between this
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
That’s great. If there’s no solution to level out the back seat down - at least this will fit the ARB Zero fridge inside with plenty of room to mount and store other stuff.
Chrome_Pony
Chrome
The Great Land
Plenty of time before the Bronco gets here to wire up a magnet switch to turn on an LED light set under there. I might have to pick one up.
bmclain
Blue Springs, MO
2013 Ford Explorer, 2021 Ford Bronco Badlands
I've been waiting for someone to pick one of these up. I've got 2 questions. How easy will it be to remove the top if I want to put something back there that's taller without removing it. And the second I will have to wait on. I was wondering if the top does come off will the doors still fit in there?
TheWanderingBrewer
Adam
Kansas City, MO
2014 Ford F150
They say this doesn't work with the drawer system, that be said if there is a will there is a way.
I'm planning the same idea with the ARB fridge. With rough dimension it should fit. Having access to pretty much all the accessories I have one on order to test fit. I am also going to be getting a fridge slide to make life easy so I'll test both ways.
This would totally awesome!!
Two bolts and the lid pops right off. Hardest parts was sandwiching the nylon washer that helps it pivot smoothly. That being said, still easy. You still have access to the floor anchors so as long as there is a enough room on the sides they should fit. Once I get my Bronco I planned on doing a install video. So I can test the door idea before installing the lid!
scotts418
Cincinnati
Wrangler 392
Good to know! If I go soft top, this seems like a must have. Thankfully, because the top bolts off I can remove when transporting the dog in the back.
redone17
Cold Spring, NY
I was concerned it wouldn’t fit with the slide. But, I’m unsure of the added height. I was also hesitant to drill holes in the floor of the cargo area for it. I haven’t decided if having the ability to pull it out of the cargo area has any benefits.
I like the idea of the Molle strap sides for my Manchester propane tank and other things I don’t want moving around.
I’m loving the ARB fridge. We’ve been using it at the house for backup beverage when we have guests and have been testing out it’s capacity and ability on 12v AGM battery. Very happy with its performance.
We’re taking it on its first real trip for some beach camping this weekend. I’ll be sure to follow up in the fridge thread about my experience in those temps, etc. I bought the cover for it for extreme ambient temps.
TheWanderingBrewer
Adam
Kansas City, MO
2014 Ford F150
Exactly why I want it! I occasionally have my laptop bag and other items I don’t people to help theirselves to. I want to be able to have fun with the top and doors off but yet be secure.
