Turn Offroad | Aftermarket Hard Top NOW AVAILABLE
H0pelessOpus
2023 Badlands; 2022 Maverick Lariat
Just checked mine (as I have a loud rattle coming from the back somewhere)
there’s virtually no play in mine. Struts seem secure and barely move.
( for the record, I don’t think my rattle is from the hardtop)
Thanks for checking!
604Bronco
British Columbia
www.bronco6g.com
For those of you with your hard tops already, how do you find it easiest to remove the targa top?
I know that may seem like a stupid question, but I have a physical disability that makes this a little more challenging for me. It’s not so much the weight of the targa top, but the awkwardness of it.
Curious if anyone has any tips they can share on how they find it easiest to remove?
Thanks!
Kjbeggs
Kelly
2019 Ford Ranger
Thanks!
I haven’t found an elegant way to do it yet. I’ve tried with my wife and I on each end, having her pass it over to me, at which point I balance it as I step down. And I’ve tried with one of us inside, lifting it as the other moves it off. Neither is particularly graceful.
I’m looking forward to seeing TORs flip back accessory.
604Bronco
British Columbia
www.bronco6g.com
It’s definitely a bit awkward. I find lifting it from inside in the middle gets everything free, and then I realize “now what?”
Hoping someone might have a suggestion that one person can do this easily.
Razorback
Bill
Dallas
Lincoln MKX
@604Bronco I've put a towel on the passenger side top behind the targa top so as not to scratch the top. Roll passenger window down and keep door open. Then lift in the middle and move top to the passenger side and slightly back on the towel just placed. Then get out and lift the part outside with one hand and the middle inside with the other. I get to a point I can now lift all of it from the outside. For one person it is awkward, but I've found this works best for me. Just remember the towel so nothing gets scratched....
604Bronco
British Columbia
www.bronco6g.com
That’s actually a really good idea - Thank you! I’ll give that a shot next time. I always have a large towel in the garage. Appreciate it!
JediMcMuffin
Tommy
2021 Bronco Badlands
The Issue:
The noise/rattle is present regardless of whether the glass is open or closed. You can feel the vibration in the glass at the same time as the noise occurs.
My Suspicion:
I suspect the ball joint that attaches the rear glass to the strut is loose, causing the glass to rattle over bumps (potholes, expansion joints, railroad tracks). The noise has become more frequent over the past week.
Appreciate any insight you all might have!
I am chasing this same noise. Every significant bump in the road makes it heard, and it appears to be getting worse. I am replacing the hardtop bolts with rockworkx quick remove bolts today. I'm going to go thru all other hardware spots to look for issues. Are you running a roof rack? I have the trailrax installed.
JediMcMuffin
Tommy
Just replaced those six main bolts with the rockworkx, and then went over nearly every bolt back there. The strut mounts to the top of the glass were pretty loose on my passenger side. One of the four phillips screws holding the lower strut mount to the top itself on the drivers side snapped off entirely with barely any pressure at all applied, but I don't think thats contributing to the noise.
might just have to live with it, though I do intend to have TOR give my top a wellness check once the replacement glass with the defroster is available
@Turn Offroad : I assume we have to be pretty darn careful tightening some of these?
FlyingBronco
The Don
Orange County, CA
All - I'm trying to diagnose a noise coming from the rear of my top while driving. I'd be grateful if anyone with a top installed could test the amount of play in their rear glass. See video below.
Troubleshooting Steps Taken:
Checked top alignment (front to back) and bolt tightness.
Removed all items from the cargo area and uninstalled the tailgate table.
Drove the same stretch of road with the rear glass open and closed.
Sat in the cargo area during test to isolate the origin of the noise.
The Issue:
My Suspicion:
I haven’t had that noise yet. But I do get a fair amount of squeaking noise when hitting bumps. Seems like the rubber strip on the bottom of the rear glass is causing it when shaking along the tailgate. I’ve tried cleaning it and putting some oil/lubricant but it doesn’t help. Not sure what to try.
FlyingBronco
The Don
Orange County, CA
I have
Haven’t tried the towel method on the roll bar/top, but I should. I do something similar to you in that I open the passenger door, window down, lift from the inside, maneuver the top to the side as much as I can and gently set it down, then I put one arm on the outside of the roll bar and keep the other inside, then lift and maneuver it over til most of the targa is on the outside of the roll bar, set it down gently again. Then I get out and lift it a last time, setting it on a flat table with a towel. I do the same to put it back on, take a bit of balance but it’s now maybe 60 seconds and I’m done.
Razorback
Bill
Dallas
Lincoln MKX
604Bronco
British Columbia
www.bronco6g.com
As far as rubber squeaks, I got this for the OEM top for my wife. I haven't taken the time to put it on, but been told it's a magic cure. I believe Ford uses it (which by the price I'm sure only billion dollar companies could afford it...) https://www.amazon.com/s?k=krytox+205g0&crid=2PS4GXSI3GRSS&sprefix=krytox,aps,112&ref=nb_sb_ss_ts-doa-p_2_6
My squeaking comes and goes - I reported this early on. The thumb bolts seemed to help, but it's still present in some situations/bumps. I have lubricated the seals and that didn't cure it. It's hard to pin point the actual issue - I have a slide-out security drawer full of stuff so it could be partially to do with what's in that, but I don't know for sure.
Regardless, it's still significantly quieter than the soft top!
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Mine seems to squeak in the mornings when it is cold. I'm in snow country and park outside for reference. After 5-10 minutes with the heater on it seems to stop. The squeaks are in the rear, not around the front targa at all.
H0pelessOpus
No roof rack for me. I'm pretty sure it's the struts/brackets.
Roadbeast
Dan
2022 Wildtrak
I also have the strange rattle over small bumps. I bought lube and
I also have the strange rattle over small bumps. I bought lube and hit the seals.
Also tighten the hardware. Still trying to track it down.
