@ZackDanger Your patience and time commitment to this board astounds me. You didn't provide any information that isn't readily available to anyone who spends even a modest amount of time on this site. You are to be commended for all of those you selflessly assist.Woof. This thread is giving me indigestion.
99 is only "normal" if you do not want your bronco to be built. The only reason to have a 99 is because you are deliberately delaying for MY22 or MY23 to get options that are not yet available in MY21 (Mansquatch, Mod Top, Green color, etc)
If someone wants their bronco as soon as possible, whenever your parts become available, it's imperative that the priority code be something other than 99.
There are many many different priority codes, but for the purpose of the Bronco, the only ones that matter are:
Anything 10-19, and 99.
10-19 all mean the same thing (in terms of the Bronco)... which is build this as soon as you can in the order at which people reserved. Because commodity constraints are such an issue, it is possible, even likely, that people with late reservations will receive their broncos before early reservations, depending on the spec.
You can only order a MY21 right now... whether or not they get to your order before the change to MY22 happens, that's another story altogether... but there is no way to order anything other than an MY21 because those are the only options that are available.
Priority 99 means that the order is just a place holder and Ford should ignore it when they are looking to see what Bronco's to be built. If your order is a 99 the assumption is that you don't want it built... and when you are ready to have it built, the code will be changed by the dealer to something 10-19 and only then will Ford consider it a real order to pick.
Ford will be able to produce over 10,000 Broncos a month, and there are over 100,000 Broncos ordered...
BUT
Because of commodity shortages, and because of the allocation formula, it is ENTIRELY POSSIBLE that someone could order JUST THE RIGHT Bronco from JUST THE RIGHT DEALER TOMORROW and get it in a month or so. (That Goldilocks order would be a Base or BB 4-door soft top with the 2.3 and manual.)
This is why Ford is so desperate for people to change their orders... they are so desperate that they are even forced to produce stock orders in MY21 to keep the line running because they don't have any customer orders they can build.
As long as you have a 99 it'll never get picked and you'll never receive an email (or a Bronco).
I wonder if he knows this... might explain why none of his customers have received an email... he's left them all 99.
