Damn so your dealer never changed the oil and left your old oil in that’s fucked up id get ford involved this dealer should be held acou ntable
Idk if I’d go nuclear on them, I give them a chance to make it right.
Did you end up changing the oil yourself after the discovery? If so, I would be curious to see what that oil looks like after the same distance traveled after the dealership oil change. Line all 3 of them up if possible.Oil on left has Two miles on it (one trip home from the dealer)
The oil on the right has zero miles. Yet the same oil from supposedly the same jug.
no oil on the planet can oxidize and turn that black in 2 miles (a few hours after driving it home…)
I'm not sure what type of oil some of the people on here are using, but if it's that black right after an oil change something is seriously wrong with their motor or their oil or they have been duped many times like you were in this instance. This is my oil with about 4,500 miles on it. It's time for a change. I have the 2.3.Oil on left has Two miles on it (one trip home from the dealer)
Sherlock Holmes …. you clearly aren’t.
Believe what you want to believe…
The problem is solved… I won’t be relying on dishonest people to change my oil and service my Bronco.
For the record, I won’t be apologizing to anyone!
I’ve always changed my oil in all my cars as did my dad….
Anyway, from new….my Bronco dip stick read well up into the twist…. Wondered why they overfilled the oil at the factory….?????
I changed the oil in my 2..7 at 1800 miles. With 6.4 qts in it was at max full mark….
At 6400 miles I went to my dealer to get it serviced and have this 7 quart issue explained….
The service tech explained when he changed my oil that he added 7 quarts…
That… having it measure well into the twist on the dip stick was normal.
But if ever was above the twist…that it is definitely overfilled….
(His words to my ears)
So drove home 2miles to my house… waited for the engine to get stone cold… checked my oil ( multiple times ….much to my shock!!! it was well above the twist.
I pulled the bash panel and started to drain some oil….
What I discovered totally set me back!!!
(the oil) was “BLACK” (WTF).
with this, I drained out all of the Oil…. “Black”… Black!!!!!
photos self explanatory….new oil vs 2 mile oil from Ford dealership)
Feast your eyes on (what is supposed to be) 7 quarts of fresh oil!!!!!
I’m pissed…. I will never trust anyone but myself (FORD IF YOUR LISTENING)!!!!
I hate being scammed!!!!!!
Not all Ford Service Techs are honest!!!!!
update: Just checked the 100 pound torque on the lug nuts…. They WERE NOT 100ft lb torque spec …. Nor were they torqued evenly…
