UPDATE: How to Permanently deactivate your Bronco Auto Start-Stop through the dash for free.
BroncoBuckaroo
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
I can only speak for my own experience, the hack seems to work for me if it stops I will update but super happy
Glad it worked for you ..seems to be working for a good amount of people
wetdog
Bruno
pacific coast
2019 jl
Update well it worked for a while then today it went off again .
Either im going to make pushing the ass off part of my start up routine or just get the dongle.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
Has anyone tried holding the button down while starting and keep holding it... I had a company car, a 2018 edge and couldn't modify it. So instead of splicing the switch wires together, I simply took a small wood screw and wedged the button so it would stay on. It would shut off the ASS at start with no errors. When I eventually get my truck I was just going to splice the wires on the switch so its on all the time.
Greasyfingers429
Adam
RI
VW Jetta TDI, Range Rover Sport Td6
make sure you have your system updates on ...I don’t recall seeing this feature before when I first got my Bronco. But the start stop section is on there now.
I remember seeing that menu when I took delivery in December 2021.
I do wonder if this “feature” has been remotely disabled by an over-the-air update on mine though, since the procedure didn’t work for me.
Greasyfingers429
Adam
RI
Nope, that doesn’t work. The system only disables itself when the button is released. This must be what the eliminator does electronically every time you start the vehicle.
Strykerwsu
Wichita
Holden Commodores
Seems since I've removed the doors that it never Starts / Stops. Assume one of the many electronic gremlins designed into a vehicle that is designed to remove doors.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
As someone mentioned earlier, I think auto start-stop is not used when towing a trailer, but not absolutely sure as I am still without a Bronco. Has anyone with a 7-pin plugged in a plug tester?
That should simulate having a trailer attached as far as the vehicle is concerned. For a few bucks, it might be worth a try.
Ford Bronco UPDATE: How to Permanently deactivate your Bronco Auto Start-Stop through the dash for free. tester
something like this.
