- First Name
- Eric
- Joined
- Jul 10, 2021
- Threads
- 35
- Messages
- 1,251
- Reaction score
- 4,033
- Location
- Sacramento, California
- Vehicle(s)
- 2017 Raptor
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
4/10/24 Major rebuild after breaking both fronts CVs in Moab back in November and getting ready for the trip to moab in three weeks.
https://www.bronco6g.com/forum/thre...g-both-cvs-hells-gate-moab-video-added.84865/
Installed the "The Ultimate Dana 44™ AdvanTEK® Front-Drive Unit". Staying with the 4.70 ratio. Spicer Extreme™ half shafts. A new set of coil-overs from Procomp. Installed the Hoss 3.0 rack and program which I had for over a year but never need it. New Bay Area Metal Fab winch bumper. The old JCR winch mount just stuck out to far and hurt my approach angle. Worked fine held up to the pulls.
Custom made skid plate for the transmission. Fab shop cut off the two side support brackets that come on the 2.7s that go from the transmission cross member to the side of the frame they hanged down about 1.5 inches and were beat and bent. The new skid on the top side has an x pattern tubing for added support not for the rocks but for but for strength in tie the two cross members together. Also has thick side rails going up for rigidity. Lastly drilled and cut to moved the rear shocks up.
Moab here I come.
4/21 23My AMB Build so far, still need a mod bumper winch mount and a leveling kit once I have the winch installed. Winch will not be the Ford mount.
On order: Burger Motorsports JB4 Tuner, any day now.
Installed:
Roof lighting, Rigid Industries 40 inch Curved RDS Sr-series Pro Spot Light Bar PN 88431.
4 Wheel Parts Factory Ford Bronco Rear Bumper with Rigid-industries-d-series-pro-flood-surface-mount-led-light-pods-202113 and Smittybilt-delta-d-ring-4-75-ton-black-99047.
Front Lights on the modular bumper.
Rigid-industries-sr-m-series-pro-flood-surface-mount-led-light-902113.
Rigid-industries-d-series-pro-spot-surface-mount-led-light-pods-202213.
Rigid-industries-d-series-surface-mount-flood-led-lights-amber-202123.
Exhaust MRT Trail Rated Axle-back Turn Down Tip 90R232.
ZROADZ Slider Side Steps for 2 Door Model - PN# Z745421
ARB M220 Dana 44 Rear Differential Cover.
BORA One inch wheel spacer, Black Aluminum.
Heritage Bronco Fender Badge.
Moab here I come.
Installed:
