- Jimmy
- Jul 19, 2020
- 6
- 1,443
- 3,890
- Northern Alberta
- 2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
- Black Diamond
Wish we had Offrodeo up here
Go back to the opening post and read the latest update from 7/29 at the top.So sorry this happened.
Curious as to what "a lot of sand underneath means"?
My thought from watching Ford Bronco Marketing videos, is that I could do pretty much as I please in terms of off roading within reason. Sure there's limits, but what are the limits?
Hello Ford? What's up?
Not true. My present vehicle is a Kia Stinger. it was a new model when I bought it. No issues and have had it for 3 yearsAre some of you new to Earth?
When a brand new model comes out, from any manufacturer, there are ALWAYS issues. If the hard top issues from a vendor are freaking your tender sensibilities out this much then you were probably driving it to the mall and not off-roading anyway. Some people revel in finding fault and pointing their crooked fingers in every direction they can, especially online.
Well, what I was talking about had nothing to do with a single person buying a single vehicle and having no issues with it. What I was talking about, clearly, was that when manufacturers put out a first run vehicle, in general there are issues that pop up. I'm very happy that you're single vehicle in 3 years has had no issues for you. But that has absolutely nothing to do with the point that I was making. #Comprehension. Its a thingNot true. My present vehicle is a Kia Stinger. it was a new model when I bought it. No issues and have had it for 3 years
Agreed. There have been plenty of new vehicles that have been released with no real issues.Not true. My present vehicle is a Kia Stinger. it was a new model when I bought it. No issues and have had it for 3 years
That is a ridiculous solution. The dealer isn’t rebuilding the engine, they are simply swapping it out with a new assembly from the factory. It happens all the time and isn’t problematic.Honestly, you should ask for a replacement vehicle. The last thing you want is a brand new car that has had the engine replaced by the dealership. That’s asking for trouble and it’s not what I would consider resolution.
Exactly. It not like a one-off engine swap to a 5.0 L Coyote. It's a bolt-in part change no different than if a wheel bearing or axle shaft went bad.That is a ridiculous solution. The dealer isn’t rebuilding the engine, they are simply swapping it out with a new assembly from the factory. It happens all the time and isn’t problematic.
Some people on here have very unrealistic expectations.
TFL had the exact same situation with their first Defender (although the engine didn’t fully seize). Their dealership offered to replace the engine, provide a refund or offer a replacement vehicle. They declined the engine replacement on similar grounds and instead accepted a replacement. Granted they are TFL and were probably treated as a higher priority customer. But, still, their rationale in forgoing the replacement engine was solid and I agreed 100% with Roman on this. I wouldn’t consider a replacement engine in a new vehicle a resolution.That is a ridiculous solution. The dealer isn’t rebuilding the engine, they are simply swapping it out with a new assembly from the factory. It happens all the time and isn’t problematic.
What is "TFL"?TFL had the exact same situation with their first Defender (although the engine didn’t fully seize). Their dealership offered to replace the engine, provide a refund or offer a replacement vehicle. They declined the engine replacement on similar grounds and instead accepted a replacement. Granted they are TFL and were probably treated as a higher priority customer. But, still, their rationale in forgoing the replacement engine was solid and I agreed 100% with Roman on this. I wouldn’t consider a replacement engine in a new vehicle a resolution.
What is "TFL"?
Yes it is you.
And wait another year for it to be built? Using TFL's Defender as an example isn't valid here since they were able to get other Defenders on the dealer lot. Having a replacement engine is not a big deal and will fix all their problems. And guess what? If they have other problems because of the engine replacement, those will be covered under warranty, too.Honestly, you should ask for a replacement vehicle. The last thing you want is a brand new car that has had the engine replaced by the dealership. That’s asking for trouble and it’s not what I would consider resolution.
