4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
We made our own pigtails today (which we'll be offering for sale soon).
Are these for the HD Modular bumper? And are they currently for sale? If so, can you please post a link? Thanks!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We've put together 3 harnesses to cover almost all of the lights you'll need. They are coming soon but available for pre-order from our site.
Each one is 20" (so you can reach any of the fog lights, especially if you run a triple fog light kit from us). One end has the connector installed for the light (plug and play) and the other end has the Ford connector. So you just plug it in, do some programming and swap in your new switch panel from Ford. It's a pretty easy process once you get the right switch panel (see that thread for info).
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
The DT 4-Pin version is used on lights such as the Diode Dynamics SSC1, SSC2 and SSC3 w/BackLighting. It has the back-light control wire on it.
The DT 2-Pin version is used on lights such as the Diode Dynamics SS3 (without backlight), Rigid D-Series, KC HiLITES Flex, etc...
The WP 2-Pin version is used on Baja Designs S1, S2, Squadron lights.
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
Excellent! Thank you!
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
Not sure if anyone has done this yet, but the CrystaLux DT 2-Pin to MX150 Pigtail sold by @4x4TruckLEDs.com works PERFECTLY when trying to connect the Oracle fog light kit to the preexisting wiring. I just swapped in the switch (M2DZ-11654-DA) and did all the FORScan changes, and BOOM! The Oracle lights work perfectly.
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
Brandon, Thank you for sharing . I rolled around under the front end looking for factory wiring and decided I better go inside and see what was on Bronco6G? Fortunately, I had "watched " this thread and you popped right up! I Pulled the pins to remove the covers and poof. THANK YOU,Thank You . There my OEM fog connectors were. TADA. After Reading the rest of the thread , I ordered pigtails from Adam at 4x4 to get me from The Ford connector over to my Fog lights. I didn't quite follow your fuse tap on the purple wire and purchased a marker light tap from Specialty Performance. Of course I had to order an extraction tool for the Deutche Connecter to pull the pin to move the purple back lit wire over to the new pig tail. As I'm now waiting on parts ordered over the weekend to complete the harness install, I decided to install my dual fog switch. It took 2 minutes to walk out to my shop to retrieve the switch assembly and less than a minute to pull the panel down, swap the assembly out and push the panel back up. Pretty darn easy when someone gives you step by step clear concise directions. Thank you again. George
Puddle Jumper
James
Lewis Center, Ohio
2020 Ford Edge Titanium AWD
Kjbeggs
Kelly
2019 Ford Ranger
I ordered these as well. Should be delivered today. I've already added the Oracle lights and the switch with the fog light button, just need to plug these in and do the forscan mods
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
Sweet. That stuff should be quick. You'll definitely need to zip-tie the pig tail and the Oracle wiring to make it a clean installation. Also, the ends of the pre-existing fog light wiring actually slide off the things that mount them to the interior of the bumper. That makes it way easier to take the caps off the ends before plugging in the pig tails.
Kjbeggs
Kelly
2019 Ford Ranger
Thanks, I've definitely got zip-ties at the ready!
Luyi_PR
Enrique
Puerto Rico
Tesla Model Y, BMW X5 xDrive45e
I did all OP steps somehow ended up with just power to the passenger side fog. Any idea or help will be appreciated.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ford Bronco Updated:Fog lights added and connected to factory connector AC485AB1-E58C-4EDC-9D90-7DC6F49F8F7F
Did you connect the driver side fog to the driver side pigtail behind the tow hook... you need to hookup both sides
