- Dick
- Apr 12, 2021
- 88
- 7,503
- 25,546
- PNW
- Website
- www.TD-Distributing.com
- 21 Bronco, 88 Bronco II, 03 Ford F250
- Badlands
Time for another oil change and I started looking into upgrades. The FL-910S is the spec for us, but many other people with other 2.3 equipped cars have switched to the FL-400S. Additionally, the Mobile 1 M1-209 has been discussed as another step up further. I haven't pulled the specs on it yet.
FL-400 Specifications:
Thread Inside Diameter (in.): 3/4"-16
Outside Diameter Top (in.): 2.98"
Outside Diameter Bottom (in.): 2.98" Length (in.): 4.14"
Spin-On Filter: Yes
Bypass Valve: YES Color: White Burst
Pressure (PSI): 250 psi
Pressure Relief Valve: YES
PSI Relief: 20 PSI
Micron Rating: 80%@20um
Height (in.): 4.14"
Seal Outside Diameter (in.): 2.75"
Seal Inside Diameter (in.): 2.40"
Anti-drainback Valve: YES
FL-910S Specifcations:
Thread Inside Diameter (in.):3/4"-16
Outside Diameter Top (in.):3.15"
Outside Diameter Bottom (in.):3.15" Length (in.): 3.36"
Spin-On Filter:Yes
Bypass Valve:YES
Color:White
Burst Pressure (PSI): 250 PSI
Pressure Relief Valve:YES
PSI Relief:14.5 PSI
Micron Rating:50%@35um
Height (in.):3.36"
Anti-drainback Valve:YES
I'm picking up a FL-400S tomorrow and possibly the M1-209 to compare. Both of these are taller than the FL-910S but it looks like there's plenty of room.
FL-400S next to M1-209 and FL-400S next to a FL-910S.
Spin-On Filter: Yes
PSI Relief: 20 PSI
Height (in.): 4.14"
Spin-On Filter:Yes
Bypass Valve:YES
Color:White
PSI Relief:14.5 PSI
Height (in.):3.36"
