Bronco4lyfe85
William
2019 Challenger Scat Pack
😂😂 Go home 4 door you’re drunk.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
It happens to the best of them.
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Actually the driver was in the wrong mode and only had rear lockers on.
shouldnt use sway bar disconnect in sand ..it will just dig in more..you don’t want that.
you only use sway bar disconnect if you need more articulation.
he also turned into the sand hill rather than straight on, not very much momentum. They never do say if he lowered the pressure in the tires which is needed for sand.
Ford Bronco Video: 64 MPH on the highway, and a Bronco helps stuck Bronco @ Moab F0A48DED-9961-4F0A-A058-3C88EB97B879
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
Reverse gear is only used to pull someone out when it'sa company vehicle....never do that with your truck. Using reverse is a no-no.
broadicustomworks
Hanging Rock, North Carolina
Still sticking up for the 4 door that tried.
:D
guzie
Kevin
Grand Rapids
2019 Subaru WRX sti, 2019 Ford Mustang GT
Ford Bronco Video: 64 MPH on the highway, and a Bronco helps stuck Bronco @ Moab FA97AAC1-758F-41F8-91CE-56686364CD1F
Yep. Multiple wrongs in his approach. One other to mention was driver overconfident.
Beach_Bum
St. Augustine, FL
Was that Shelby driving the 2-dr on the recovery? I tried to freeze-frame the video and spied the longer hair. Also, the radio communication is with a female's voice.
MyATV
ATL
Maybe the music selection stopped the Bronc in its path...?
Ford Bronco Video: 64 MPH on the highway, and a Bronco helps stuck Bronco @ Moab 1617622190868
mpmcgaughey
Matthew
Houston, TX
2015 Ford F-150, 2022 Ford Bronco Wildtrak
2 door > 4 door 😎🙌🏻
Pancho Kornwallace
Pancho
Mustang
Using only your comments, I can tell what type of Bronco that you pre-ordered, in most cases.
We’ve all got that friend that tries to hang but just can’t keep up. Let’s remember to lend a helping hand when it happens. 😀
✅A 2-Door pre-orderer flat out "zonks" the 4-door, no hidden move here.
I wonder if a Sasquatch 4DR would have made it?
✅A 4-Door with SAS pre-orderer tries a misdirection argument.
At least they could've slept in the back of the 4dr when they get stuck
✅A 2-Door pre-orderer goes ju jitsu style with the argument, by using the strength of the 4-Door as a back handed zinger.
✅A 4-Door pre-orderer tried the "it's you, not the Bronco" argument. Also perhaps a Cyber Orange reference.
✅A 4-Door pre-orderer tries the technical jargon approach of "professional does not know what they are doing, but I do." To be fair, i do this with the Lions all the time, "I played Madden, so I know what I am talking about. They should have gone for a quick out on 4th and 2 instead of the QB sneak, as the CB was playing off the receiver."
...They should have put the 2 door up on the hill to see what would have happened....
✅ A 4-Door pre-orderer tries the "it's better to have tried and failed than to not have tried at all" argument.
Or
✅A 2-Door pre-orderer is modestly/politely asking for the "rub it in moment".
*** This is the only one I don't know. ***
They need to put a cape on that 2dr because it swooped in like a superhero. Then, the video just stops after the hero saved the day.
✅ A 2-Door pre-orderer knows they won, and now wants to see the celebration, the confetti, the trophy presentation and all of the interviews in the post-game show.
