Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
Front seat Height adjustment uses the recline handle sorta like a jack handle. I wish the big and talls that mentioned low headroom would have specified if they tried this, it's a pretty large span of adjustment.
Also, the rear seat recline looks like it stops just before getting into the rear fender well hump projecting into the cargo area. My family of 5 (three teenagers, one adult sized) can make this space work for a 3 hour ride to the Gulf no problem. Its all in what you want it to be.
Front seat manual height adjustment range, measured by @Tricky Dick
Ford Bronco Video Demonstrated: Manual Front Seat Height and Rear Seat Recline Adjustment Range img_20210502_105154040_hdr-
Ford Bronco Video Demonstrated: Manual Front Seat Height and Rear Seat Recline Adjustment Range img_20210502_105131779_hdr-
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Give me about 8 hours, I'll get a measurement of the adjustment range.
Update: Here's the measurements.
stonerdoom
chicago
2004 Ford Explorer Sport Trac
I'm curious if there are adjustment measurement differences between the electric seats vs the manual seats.
Happytown
Happytown
Ryan
Zachary, Louisiana
hmmmm can't answer that but there were both electric and manual versions at our event. I'm pretty "average" at 5'11" I guess. Both versions felt right at home to me somewhere in the middle of the adjustment range. Big n talls, and the vertically challenged probably really need to sit in one based on the wide range of impressions returned to the forum.
Razorback
Dallas
Lincoln MKX
Those Texas Tech fans should be really fast at raising those manual seats...
Happytown
Happytown
Ryan
Zachary, Louisiana
Ford Bronco Video Demonstrated: Manual Front Seat Height and Rear Seat Recline Adjustment Range tenor
I Hate to be critical of someone's effort @Tricky Dick, especially in the forum environment, but I think your tape is resting on two different elevations on the floor mat? I only say that because the adjustment really felt like more than the 1" difference the tape is showing. What say you?
Tricky Dick
Dick
PNW
In hindsight I think I might have it on the little bump. The low setting should be about 1/2" lower than indicated. I felt very rushed on top of the excitement having my head spinning.
5280Bronco
Denver
I know the OP already responded to this, but i also just wanted to say i bet that the difference in height is greater at the rear part of the cushion as you adjust it up and down, essentially changing the angle of the cushion and making the change feel greater than just the front measurements would indicate. Does that make sense?
Happytown
Happytown
Ryan
Zachary, Louisiana
I think you are right. I think you can see the seat moving through the arc as you described as it comes up. I know that in person it was a pretty big difference in feel, from going full down to full up.
Also, I'm so bored waiting on the Bronco, seat height adjustment is interesting to discuss at length right now lol.
Tricky Dick
Dick
PNW
I actually watched for that and if the angle changed it was very minimal. It does move back as it moves down, and I didn't slide it back forward before measuring. The tracks are likely at an angle so it probably gains height as it comes back forward. So my measurements are probably not terribly useful, sorry.
Tricky Dick
Dick
PNW
I will say, the lowest position was far lower than I will ever use at 6ft tall, and my 6'7" brother had lots of headroom in that position. VVV
Ford Bronco Video Demonstrated: Manual Front Seat Height and Rear Seat Recline Adjustment Range IMG_20210502_105403556_HDR~2
Happytown
Happytown
Ryan
Zachary, Louisiana
Nah man you done good work @Tricky Dick ! A person just gotta go sit in one to really tell anyhow.
SnowBronco
Canada
You worked with what you had... We appreciate you either way lol
Ford Bronco Video Demonstrated: Manual Front Seat Height and Rear Seat Recline Adjustment Range blow-kiss-flying-kiss
Rlack75
Ron
Marietta GA
Watch the seat in relation to the side pillar in the video.
Happytown
Happytown
Ryan
Zachary, Louisiana
Yep kinda looks like it dumps forward as it comes up.
