Vintage Bronco Chrome quarter panel Lettering
peterh
ny
jeep wrangler jlu 2018
Was thinking of putting these on the side quarter panel but wonder if they may be a little cramped looking, especially if you add a side stripe.
here it is on an old one and here is a pic of a new bronco to see how much room there is on that quarter panel
I think it works - thoughts?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
I am thinking the same. I figure once I get the Bronco, then I can figure out how much room there is.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I want the same thing! Was hoping there would be an after market version that sticks on vs the vintage one that requires holes to be installed. I imagine the Heritage edition will come with those
Easy enough to grind off the studs and apply double sided tape.
dgorsett
colorado
F250, Mustang, Explorer
I've had the BRONCO script badges in my Amazon wishlist for a while. Went to order but pulled the trigger on the "kicking horses" instead. Wondering the same thing about fit. Probably be fine if you removed the "trim badge" or had a Base without one
Ford Bronco Vintage Bronco Chrome quarter panel Lettering 41Lj-yt5ZiL._AC_SX466_
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '05 F-350; '07 Camry
Likely gonna wait to see what the aftermarket comes up with, sized right for the new quarter-panels.
...but the black chrome pony from the Wildtrak is going onto the tailgate ASAP
lobbs611
Kyle
Independence, MO
2D JL Rubicon
Having lived thru a retro reboot of an icon with a 5th Gen Camaro SS there is a very fine line to walk between adding some additional vintage inspired awesomeness and tipping over into gawdawful tackiness. This was true of the Mustang and Challenger communities back in the late '00s/early '10s as well.
PSUTE
Western Maryland
Sierra
Not gonna lie, for the additional thousands on upgraded package, you guys who are not going base deserve better than a crappy sticker. Gonna go with the script on my base...
Brownie
Maple Ridge, BC Canada
Bronco Badlands, 1981 Trans Am, 1972 Austin Mini
Carolina Jim
Highlands
2021 Bronco 2-door
the old ones will be tight....might have to leave off the last "o"
Hey19
JJ
Bethlehem
I was going to go all semantic and say you’re referring to the fender, not the quarter panel. Then I thought about it, and on the Bronco, both the quarter and the fender is easily removed. So does this make both of them fenders? At any rate, I think the Base deserves the script or the bucking horse emblem since it’s the essence of Bronco.
