I saw this picture of the side steps in another thread. I don't think the metal lip with holes above the steps is a good look. Will the rock rails hide it? If so I'll consider changing from steps to rails.
Thanks for the reply. I'm switching to rails. As I won't be rock climbing I'll call mine beauty rails. LolCalled a pinch weld and yes ugly af ... rock rails will solve the problem ..
I finally have a reason to keep them... But I still want tube steps.....?Thanks for the reply. I'm switching to rails. As I won't be rock climbing I'll call mine beauty rails. Lol
Exactly.On OB the tube steps are standard. You can order the rock rails. Does this then replace the tube steps or are the rock rails just added? The B&P just shows the rock rail as an addition. Not sure if it’s a glitch. Anyone know?
I can't imagine that would bother me at all. If it does, some rubber plugs in the holes would make them disappear.Between Ford and/or the aftermarket, there will be a simple strip to cover the pinch seam.
Are those the Ace sliders that bolt up to the stock rails?I prefer the rock rail and slider look.
Yes they are. The sliders were mounted where the frame meets the body. About a 1 hour job with only me doing the work.Are those the Ace sliders that bolt up to the stock rails?
