Warn VR EVO 10-S 10,000lb Winch with Synthetic Cable 103253
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
If anyone is in the market for a winch we have plenty in stock but check out the EVO 10-S
Message me for a discount code.
Frank
Ford Bronco Warn VR EVO 10-S 10,000lb Winch with Synthetic Cable 103253 1635958317143
Warn Evo 10S Highlights:
  • Rated line pull of 10K lbs
  • Fitted w/ synthetic rope & hawse fairlead
  • Uses 3-stage planetary drive gear
  • Features 2-in-1 remote w/ wireless capability
  • Aids in off-road recovery
Pulls 10,000lbs with a Reliable Construction and Stylish Design
Getting a High-Quality Warn Winch doesn't have to break your bank, and the Warn VR EVO 10-S is hear to prove it. Warn's VR EVO 10-S offers up an awesome look, compact design, and nearly unmatched reliability into a single 12V DC winch system that can handle practically any job or recovery task for your off-road vehicle of choice. This version of the Warn VR EVO Series winches is rated for a 10,000lb pull while drawing 358 amps, which makes it perfect for Jeeps, half-ton trucks, and other similar-sized vehicles. The winch comes with a standard 10x4.5" bolt pattern that allows it to mount up to most winch plates and aftermarket bumpers without any issues. The system uses a synthetic cable and hawse fairlead for a more reliable pull over competing brittle steel cables. Powerful Motor, Adaptable Controls, and Extremely Strong Case
Each VR EVO 10-S winch is built around a powerful motor and durable case that gives it awesome pulling power and unprecedented reliability. The winch utilizes a Warn series-wound 12V DC motor that combines with the winch's 3/8" synthetic rope to give the winch a total rated pulling power of 10,000lbs and pulling speed of 5.2' per minute. The VR EVO Series winch comes standard with a cast aluminum, one-piece tie plate that gives the entire winch assembly greater structural strength than tie bars. Each winch has a convertible control pack that allows for upright or low-profile mounting positions and uses a waterproof Albright® contactor to ensure excellent reliability. The winch also comes with a remote switch that uses two-in-one plug in remote for wired operation. If you desire, the remote also has wireless capability. Each winch comes standard with an aggressive black finish that gives it a great look. Warn backs each winch with a Limited Lifetime Warranty.
Winch Specs:
  • Rated Line Pull: 10,000lbs
  • Geartrain: 3-Stage Planetary
  • Gear Ratio: 218:1
  • Clutch: Freespooling
  • Brake: Spring
  • Mounting Pattern Width: 4-1/2"
  • Mounting Pattern Length: 10"
  • Rope: Synthetic. 90ft x 3/8" diameter
  • Fairlead: Cast Iron Hawse Fairlead
  • Bolt Pattern: 10" x 4.5"
  • Remote: 2-in-1 plug in remote w/ wireless option
