I agree with you. These tops aren't the best. I previously owned about 4 Wranglers. Those tops weigh a ton and are strong as hell. Ford took the cheap, lightweight, gas saving approach. I'm still waiting on a good soft top option.
I believe there are a couple threads where people have. But of course there isn't any long term results yet to see how it holds up.Has anyone tried this?
Do you recommend removing the guide pins while the top is still on, or is it easier once it’s off? I just tried unscrewing my guide pins while top is still on and they are rather tight and not loosening up, so I’m being cautious. Maybe I need to take out all the hold down screws first then try.Just remove the two small torx screws and the plastic locator should just fall off. If it stays in the body, give it a few taps and pull it out.
I think the plastic bushing has a shoulder on it and won't come out until the top is off.Do you recommend removing the guide pins while the top is still on, or is it easier once it’s off? I just tried unscrewing my guide pins while top is still on and they are rather tight and not loosening up, so I’m being cautious. Maybe I need to take out all the hold down screws first then try.
The torque spec for those bolts is 106 lb.in.I think I read somewhere that the torque on the bolts is 14-15ftlbs. That’s seemed like a lot to me but maybe it’s not.
I’m removing my guide pins. I’ll just get a couple of bolts, cut the heads off and use them as guides when reinstalling my top. The guides are handy with the lift I use. There is no reason I’d ever position the top on the body if it’s not aligned exactly where it should be.
I use a Toplift Pro which is extremely quick and easy.
I fortunately have a huge garage……needed with the Toplift.
I’ve removed the top 10-12 times with no problems, but I’ve never set it on the ground….yet
At least according to the Workshop Manual it's 106 lb.in. The owner's manual says 13 to 17 LB.FT. That's close to twice as much. Just snug them until they feel right!The torque spec for those bolts is 106 lb.in.
After reading this thread, I’m going to remove my guide/locating pins like others have suggested. I assume the top won’t be any weaker without them since they are really just guides and you still have 4 bolts on each side? Agree?
I don’t even think putting a stronger metal bolt in there as a replacement guide pin is even worth it if the bottom flange of the hard top is the weak point anyway that’s cracking.
When reinstalling the top without the guide pins and using two people, is it likely or not that the top could slide off and fall to the ground prior to you getting a couple of the screws reinstalled? Of course anything is possible, really just wondering if it can rest on the frame long enough without the guide pins to get the first couple screws in (only talking like 1 minute really).
