Allagash
Keith
Rode Island
2023 Bronco BL, SAS, LUX / 2017 Super Duty
With the number of issues I've read about with these hard tops I made the decision to order mine with the soft top and to wait and see what the aftermarket world comes up with first. I'll run the soft top for a year or two then see what's on the market and buy whatever has proven itself to be the best top. Even if it costs me upwards of 5K I'm okay with that.
Allagash
Keith
Rode Island
So if I can ever order a Bronco. I should be happy with a soft top and hope for a good and reasonably priced aftermarket hard top
Better than stock...most likely. Reasonably priced...? Highly unlikely.
JohnnyBronco
Pennsylania
X4
More like never remove the top under any circumstances...I was already planning on never removing doors so I guess I'll add the hardtop to the list as well.
I've mentioned here before and I will again that I have a feeling Ford will be replacing our MIC 2.0 tops within the next year or two.
Replacing with the very few issues softtop. Although I am hesitant to remove rear windows since if the $1.00 connecting tab breaks you have to replace the whole panel. Never opened past first position yet and doors stay on u til warranty runs out
JohnnyBronco
Pennsylania
X4
Way upwards, so far.
mpeugeot
mpeugeot
Good luck with both.
I have the Bestop Trektop in the garage, so I will put it on soon enough.
Theowlhoothoot
DFW Texas
Model 3 Performance
Honestly, we passed on the ESP the second time around with Ford. They refused to honor things like having a rental available for service and after reading the fine print almost nothing is covered besides engine.
mpeugeot
mpeugeot
I have a 21180 2.7 engine, middle of the hot zone, so that's why I purchased the warranty. If it shells out and they replace it... or if it never shells out. I will be happy with either outcome.
mike8675309
Minnesota
Not a bad idea. Any worry about the weight being on the rubber seal?
I would worry about it if it was sitting like that for a few weeks, but for a few days there is no reason for the rubber seal be damaged by it.
For Christmas this year I plan to get that fancy lift system from SmarterHome so I don't have to deal with this or worry. It'll help me have the top off a lot more next summer.
mike8675309
Minnesota
Which ESP are you talking about? There are different companies that write ESP for Ford dealers.
For example, I have the EasyCare TotalCare service contract which covers all vehicle components but (of course, doesn't cover body panels but none do that)
What is not covered:
  • Damage that occured prior to the purchase of the contract or after the contract expires
  • Adjustments to correct squeaks,rattles,water leaks or wind noise
  • Non-factory installed radios and speakers
  • Light bulbs, lenses, and sealed beams
  • Upholstery
  • Carpet, paint, ornamental moldings and interior trim
  • Convertible tops, glass, plastic, framing, cables or seals
  • Any part or component damaged by varnish, rust, corrosion, moisture or condensation
  • Damage caused by any external cause such as collision, theft, freezing, lightning, hail or flood
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
Oh, thanks for pointing that out. It is people like me who suck?
You know, I am willing to bet that the service manager I discussed the issue with would tell you that I was polite, respectful, and understanding.
Just because I am unhappy with the outcome doesn't mean that I am going to be an asshole. It appears that you might be biased against the people who actually didn't read every last bit of the fine print and never considered that the hardtop is trim.
Considering that I only loosened the bolts ONE time and it immediately broke following that, we can surmise that the factory is the only culprit that might have over-torqued it. It was not visibly cracked when I removed the bolts and didn't crack until I moved it 3 inches rearward and set it gently back down on the Bronco.
But, I am the problem... LOL 😂 Ok got it. Thanks for playing.
Polite or not, too many people have an entitled attitude these days and want something for free and that how you came off in the op. If what you say is true, and it was in fact over tightened from the factory, unfortunately theres no way to prove it. As an advisor my suggestion would be call your insurance company and start a claim.
Theowlhoothoot
DFW Texas
Model 3 Performance
  • Upholstery
It was the one Ford sold us.
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
That actually might work. Certainly worth trying.
mike8675309
Minnesota
SkiRig
Portland, OR
2018 Audi A5
This may be a dumb question, but would having the MIC top Line-Xed help with its durability or would it just offer yet another reason why the poor construction won't be covered by the warranty?
