Was about to slap down the deposit for a rubicon..
jaeggernaut
BMW M Coupe // Volvo P1800S // Caterham CSR 200
Hi all. Just saying hi and that I’ll be lurking around.
I had my heart dead set on a rubicon for awhile now for my next vehicle. But got wind this bronco frenzy right before covid. Just my luck that I arrive at the party right when it gets put on pause.
Hopefully the reveal will be soon as my current car’s lease is over in July.
2 things the new bronco MUST have:
- removable doors (it’s what makes the Jeep truly unique)
- it looks good with 37” tires (I’ve been dreaming about big tires on a Jeep since I was in my 20’s (years ago ;))
BroncoJeremie
Jeremie
Cedar city
2006 Ford F-150
Why the reveal is imminent, it won't go into production until December of this year at the earliest sooo
jaeggernaut
jaeggernaut
yup. If I like, I’ll need to figure out something in between. Do something ‘stupid’ since it’ll only be a year-ish ;)
JimmyDean
Louisiana
Well, I think you are in luck. w e know it'll have removable doors and top, and the pictures with the 35s, looks like it'll fit 37s without much effort.
indio22
Chicagoland, USA
Do we know the removable doors for sure though? The photos showed removable top, but I didn't see where we had 100% confirmation the doors come off. Would be nice if they did. The doors look more like traditional doors compared to Wrangler, that is why I wonder about how easy they come off?
JimmyDean
Louisiana
yes, it is 100% confirmed that the doors are easily removable and stow-able. What isn't confirmed is how the configuration will be afterwards, it appears there will still be a crash bar across the door opening.
Paint
Jack
Oklahoma
Tundra
You can take the doors off of anything and drive around as long as you have mirrors.
I'm just saying.
Spooled
Republic of Texas
indio22
Chicagoland, USA
JimmyDean
Louisiana
Thanks, yeah I recall that thread and had commented in it. I wasn't sure though, if we now have concrete evidence the removable/partial doors actually made it to the production Bronco. Guess we will see soon enough at the reveal.
well, the two most obvious things I can point out to you are: mirrors are mounted to the body, not the door, and the doors are frameless, meaning that with window down, they would require half the stowable space than a framed door, and also easier to handle.less bulky.
indio22
Chicagoland, USA
Yes lack of window frame will be a nice plus on a removable door, in terms of stowage. My hard Jeep doors in contrast, are bulky having the frame. Although looks like the rear door on the 4 door Bronco model, has a triangle that will stick up a bit from the door. But still better than having a full window frame.
JimmyDean
Louisiana
yeah, that triangle on teh 4-dr is not good. it means that there is a corner missing in the glass at the bottom, which is likely due to interference with the wheel well when rolled down....so, no cutting fenders on the 4 door, or at least not towards the front side of the wheel well, you'd have to only cut to the back, which means stretching the wheelbase.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
They are sort of like Jeep JK half doors with power windows, and maybe trail doors built in.
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
I wish I had just found out about the Bronco is Feb/March. I've been wanting this thing since 2004...
MaverickMan
Shane
The other thing I think for wanted with the doors is a clean look. With the hinges on the inside like normal. Gives you the clean car look instead of the military/farm look of the jeeps hinges. Style and flowing lines have always been important to Ford. Jeep if they have style its as an afterthought of hardcore functionality.
The trick i wonder about the doors is do the panels come off with it open or shut or both. Because you dont want to chip the paint on the edge of the fender, i think maybe you roll the windows down, get out, shut the door, reach in the window and pop some clips and remove?
I dont know the whole concept has obstacles, hope we see soon.
