srafferty25
Maryland
1970 Bronco
So far, there have been several documented cases of this type of leak. I'm just curious what dealers have done, so far, for others wit this issue.
I have a leak on and it is coming out the passenger A-pillar. I took it to the dealer last Monday 8/30/21 and it turns out that they sent it to a local company that does aftermarket sunroofs and convertibles, as well as leak diagnosis, to try to determine where/how the water is entering. So far, no news, but I will update with any news I get.
NotApplicable
BEVs
Just adding my experience as well… heavy rain - leak on driver side.
Noooooooooooooooo
Hopefully they have a solution for this before I move back to the rainy PNW!
604Bronco
British Columbia
www.bronco6g.com
I'm really too lazy to read all 19 pages of this thread. Someone who has read it all: Is this just showing up on the MIC tops, or is it the soft tops as well?
NotApplicable
BEVs
The flawed design seems to only allow the leak to occur when the hard top is mounted. But vehicles sold with soft tops have the same root issue, they are just asymptomatic until equipped with a hard top. As far as I can tell from this thread.
c2one
San Antonio, Texas
2021 Ford Bronco FE
I agree. I’ll just add, in my opinion, rain like testing has not been tested on a soft top. High pressure water testing is not equal to heavy down pour. The failure in design is the lack of capability to handle large amounts of water - not necessarily water applied at high pressure.
It seems that the issue is more prevalent when the vehicle is sitting at a stand still vs in motion.
that’s my take away from this thread.
that’s not to say no softies haven’t been in heavy rain - just that I haven’t seen it reported where a softie sat in rain for an extended amount of time. Unless I missed it.
Bronco21fan
Angelo
NewJersey
Yep those are the "drains".
And that is why I have been saying this is not a top issue. It will happen on all tops.
All you have to do is pour water in the channel with a water bottle and it will overflow.
The doors and windows have to be closed.
Can you send those pics of the drain tubes tweet them to mike Levine or someone high up in ford so this problem gets taken care of
redstarn
elliot lake
bronco
We sure would like your water problem resolved , and now maybe mold in there to wherever water went .
We have a hard top no leaks as of now , but never know , would yours be a soft top ?
How do we find out the day of manufacture and month ?
Bronco21fan
Angelo
NewJersey
Why don’t ford just issue the recall now a nd delay the inevitable
Efthreeoh
Hummer H3T
Not sure how many here have previously owned a convertible top vehicle, but news flash, at some point water will find it's way into the interior. It's just what happens with a convertible.
To expect otherwise is being unrealistic.
stuston
Adam
ATL
'21 Badlands, 7.3L Excursion, Multiple TDI's
My soft top has been in heavy rain with no issues. Both parked and while driving. Granted, "Heavy" rain may be somewhat subjective, but we're talking about wipers on high, still could barely see. I believe this issue has to do with the Hard Top not sealing properly to the leading edge above the windshield, and the weeping drains being overwhelmed.
Amen.
da_jokker
Jeep Wrangler JKUR
Just an idea, but back when I was trying to find a leak in my old Jeep I read about a trick. Lightly dust your weather stripping with baby powder and then pour a bunch of water on the car, ideally until you see the leak. Then when you look at the weather stripping you should see the baby powder missing/wet/etc wherever the water is getting in.
Just a thought.
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
Just wondering if these leaks are from 4-door, 2-door, or both? Be nice to be able to narrow down the issue.
rutherk1
Keith
Ohio
2021 Bronco Badlands 4 door Manual
Take the piece off. Run a garden hose against it. Find leak. Put some strip caulk where leak is. My super duty did this. Ended up being one of the clearance lights on top.
mpeugeot
I have owned several Miata across multiple generations, not one of them leaked. Hard top, soft top, switching back and forth, etc. Same goes for my Ferrari F355. It didn't leak either, and believe me, on Guam it rained plenty hard to test it. It is BS to have that kind of leakage.
