Weird thing happened with Kicker Key 200.4
AXMRDR
Central Arkansas
'22 Bronco, '02 F350 4WD Crew, couple of Harleys
A couple of months ago like many folks here I upgraded the sound system using the Kicker 200.4. I performed the Forscan changes described in the stereo upgrade thread.
I changed out all of the speakers. All of the 4" speakers were switched out with JL C2-400x. They are pretty good speakers but honestly have a little trouble when pushed hard with the amp trying to produce lower frequencies. The kick panel speakers were replaced with JL C2-650. These performed flawlessly.
I actually hooked the dash speakers up in front of the input to the amp so they were just fed from the stereo. This keeps them from being 'over-driven'.
I ran the initial Kicker Key setup and ran it that way for a month or so. Then I decided to add bass blockers to the rear speakers to help deal with the problem the 4" rear speakers were having reproducing lower frequencies. I did not rerun the Kicker Key setup again afterwards. Everything sounded fine.
After a couple of weeks the rear speakers sounded anemic, just really high frequencies. I gave in and ordered the Mabbett pods and JL C2-650 speakers to replace the 4" speakers. After installing them the new larger speakers still sounded anemic.
At the risk of thinking the speakers were defective I checked them with another source, they were fine.
Taking a test speaker I checked the input to the amp and it sounded ok meaning the Forscan settings were good. So the I checked the output of the amp and it sounded bad. The amp output was the problem.
I reran the Kicker Key setup and everything sounds great now.
The only thing I can think that happened is changing the impedance, by adding the bass blockers to the rear speakers, over time, changed the output frequencies of the amplifier output. I would never expect this to happen. As an electrician I have learned that just about anything is possible when dealing with electronic devices.
I just thought posting this this may help someone someday if they ever run into weird frequency outputs from a Kicker Key amplifier. Just run the setup again before you do a bunch of other troubleshooting.
KABQ
Aaron
Albuquerque, NM
DSP recognized the 4" rears couldn't produce lower frequencies, so it cut them to that channel. Yes, you definitely have to redo the DSP of you make big changes.
