These are built in Ukraine? I live in Texas and can clearly hear this vehicle's road noise on the highway from this photo.Anyone tried or know anything about the Wherewolftech Bolt-on portal axles kit for Ford Bronco ?
Link: https://werewolftech.com/en/catalog/portal-axles/portal-gearboxes-for-ford-bronco-2021
Clearance increase
+130 мм
Gear ratio
1 : 1,35
HUB type
6 x 139,7
Recommended wheel size
38"
Minimal rim size
17"
Recommended wheel offset
ET 60
Individually designed for Ford Bronco 2021 kit, fitted to the factory axles and brake system.
By increasing the clearance by 130mm and reducing the gear ratio by 35%, portal gearboxes WEREWOLF can multiply improve the vehicle's cross-country ability, increase torque and while unloading the transmission.
And also allows you to install a central tire inflation system.
@NC_Pinz , did you see this behavior on your Pinzguaer?The only vehicle I’ve driven with portal axles is the H1 Hummer. My only complaint is that they rock forward and aft against the gears when you come to a stop on the Hummer because the brakes are inboard of the portals. $16K seems steep, but if they are good quality then the price seems in line with kits for other vehicles.
(i don't remember rocking in the few times i've been in one years ago)
I wonder what it does to highway speeds does it become an off-road only vehicle at that point?https://www.carscoops.com/2022/10/t...ll-let-your-ford-bronco-look-down-on-raptors/
Serious off-roaders will do whatever they can to get a leg up on the trails they want to tackle. One especially potent modification is the installation of portal axles and now, one Ukrainian-based company has built the first set of commercially available portal axles for the Ford Bronco. This single modification adds 5.11 inches (130 mm) of ground clearance to the blue oval off-roader regardless of trim level but it’ll cost you at least $16,000.
Very valid point I was wondering the same thing.I wonder what it does to highway speeds does it become an off-road only vehicle at that point?
Don't expect to beat any land speed records.Very valid point I was wondering the same thing.
