What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠
Inlinejohn
WA
Several
The arch is higher than Sasquatch so I assume it means that. It has the look of more clearance. I want to put 37” BFGs but I don’t want to risk it haha
I don’t think so…I think their claims “up to 2” is if you’re starting with non-SAS flares you get 2” but if you’re staring with SAS flares, it’ll be zero. The main differences I see are rounded/softened edge and extra body surface flange to cover the fender bend.
I still think they look pretty good
killaz05
Charles
Rockledge, FL
2021 Ford Bronco Badlands 2.7 Sasquatch
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 E2AF038C-136C-4288-884C-1D5A672770E3
They are wider than sas as well. That I know. My icon wheel and tire setup use to have a little poke on the sas fenders and these cover them.
Inlinejohn
WA
Several
What is your wheel offset and tire size? Is the most outer edge of the AirDesign lower or higher than SAS flare (the edge that would first come into contact with tire during articulation)?
Herbie
Alex
Cleveland OH
2022 Badlands
killaz05
Charles
Rockledge, FL
They are the factory sas Goodyear tires with icons at 0 offset. The outer edge is higher than my sas fenders were.
Inlinejohn
WA
Several
Ok.. 0 offset is perfect. Can you share some pics before/after? Maybe I missed it but did you lift your SAS?
Hahaha..I got lost in translation and missed that you are the guy with the Bronco at the start of this conversation…Sorry about that. Still would like some before pics. Maybe some comparison shots of size changes
killaz05
Charles
Rockledge, FL
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 25D3C607-844D-4B28-9CB3-CD4D71B9AB22
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 A2CC88B2-4CCC-4384-944A-666C0F2EC0D3
No lift on the bronco
Inlinejohn
WA
Several
Might look “little” better with slight negative offset with spacers or -offset wheel? I’m deciding between 0 and -18 but maybe best with 0 and add slight spacer
killaz05
Charles
Rockledge, FL
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 1D239C92-4A43-4FDF-921C-BE02506CDA78
0 offset with sas flares
  • Like
Reactions: Cat
Inlinejohn
WA
Several
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 13CA1EC3-B135-4094-A017-A3EE4C8ABFD5
So what I’m seeing is there’s no poke with new flares and minimal poke with SAS flares
New flares are not flush w tire? Tire tucked in
Inlinejohn
WA
Several
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 F420F03F-EDAA-4672-999F-DD741831DF7B
Can you duplicate this shot from rear with new flare and ever so slight movement of camera showing how far away from flush?
bstottlemyer85
Ben
Clarksburg, West Virginia
instagram.com
2021 Bronco Badlands - NonSas
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 39885452-03FB-44FA-ADAA-57FE6D9FC057
I have the AirDesign Fenders as well, I love them on my Non-Sas Badlands. I did a write up with pictures and measurements between the fenders:
https://www.bronco6g.com/forum/threads/air-design-fenders-flares-with-width-measurements.42870/
Icon Rebound Pro = 17x8.50 | 0mm Offset
Nitto Ridge Grappler = 35x12.50R17LT E 121Q
And to keep with the thread, this weekend I added the @JcrOffroad Center Console Mollie, and the @Mountains2Metal Overhead Squatch Basket and mounted an external Uniden External Speaker for my Midland GMRS Radio and Bulletpoint MagSafe Phone Holder
JCR Center Console Mollie
Mountains 2 Metal Overhead Squatch Basket
Bulletpoint Magsafe Phone Holder
