SilverStreak02
Andrew
KCMO
22 Bronco Raptor - 02 Lightning
BLUMAK3D TrailSight Deletes
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_2032
Mabett Rear Seat Back Covers
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_2027
Mabett Front Door Storage Pockets
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 IMG_2036
I also installed the TripleALiners Center Console Organizer but didn’t take a photo.
The Mabett Rear Door Pockets and Tekk Shorty Antenna are arriving today.
vrtical
Doug
GSMNP, TN
Fords
Installed M2M door pockets I won at Supercell.
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000003666
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
Thanks. I installed the old Mabett metal ones on my Big Bend and had that problem. Was just curious if the M2M's were different.
bb163
Bend, Oregon
F250, Promaster
Spacers to protect your wheel right @bb163?
Any concern about the loading? That is a lot of force and a lot of torque especially with two bikes added to a heavy tire itself. It does look like you did an aftermarket tire/gate reinforcement/replacement. Good call if so. Regardless, not sure I would wheel very hard with the rack or rack+bikes.
Just saw that I never responded in regard to the spacers. I include cone spacers to protect the lug seat of the rim from the stud extender. I ended up making an etsy page for it.
https://www.etsy.com/listing/1721681691/1up-bike-rack-spare-tire-adapter
https://www.etsy.com/listing/1707571350/bronco-tailgate-limiter-6th-gen
swamp2
swamp2
Rockslide Engineering Tailgate Table:
This model has a high weight rating of 100 lb, has quieting bumpers, a bottle opener and magnetic clasp.
Although I'm sure the supplied sheet metal screws would achieve the stated weight limit, I opted for a stronger and more easily removable mounting method - rivnuts.
Then attached with stainless M4 socket pan head cap screws and washers.
Finally done with quick lunches on top of a cooler, on my lap or on a nasty public picnic table.
Final tip: Upper right mounting hole has a backing steel sheet behind the visible body colored one preventing full rivnut insertion. The backing sheet was safely drilled without risking wiring or other components.
swamp2
swamp2
Mabbet Aluminum Pedals:
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 PXL_20240604_022857869
I wanted a billet and more agressive bolt on set with a similar dead pedal design but decided to give these a try. They are entirely cosmetic.
I was initially concerned about the slip on design but not so after installing. The brake cover replaces the all rubber factory one and is also a slip on design. The fun pedal is slip on with a clever design preventing vertical slip which uses the small lip on the factory pedal.
vrtical
Doug
GSMNP, TN
Fords
Starting working on more stereo upgrades. Replaced the fronts with some Kickers. Also busted out the Forscan and turned on global windows up.
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000003995
Ford Bronco What Did You Do To Your Bronco Raptor Today? 🔧 🧰 🪛 1000004001
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
Those Mabbet pedals work. I have had mine on for over a year now and no issues. They look so much better.
