What is recommended tire pressure on a Black Diamond?
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Can somebody with a Black Diamond please tell me what the recommended tire pressure is as shown on the door frame placard? Ideally from a 2 door model, but I will take a 4 door since that is probably a lot easier to find out there.
Reason I am asking: I installed on my Base the same tires (General Grabber ATx) that come stock on the BD and wonder what Ford is recommending they be inflated to.
Thanks!
HBTFD
Newnan GA
F350
Thanks!
The spec should be in your owners manual.
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
I think the owners manual says 71.2607 inches of Mercury. The fourth decimal is incredibly important you’ll need a good tire gauge.
dgorsett
colorado
F250, Mustang, Explorer
Thanks!
Let's see a pic of that Base...I think the 265 75 x 16 tire should be about perfect, width, height, on and off road performance.
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
It is not, I checked. Possibly because the recommended PSI varies by trim.
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Haha that's 35 psi. I checked the manual but did not see it in there
hotrodjohn
DFW
1966 Bronco, 1975 Bronco Ranger, 1975 Bronco Sport
39 PSI cold, front, rear and spare per the sticker in the door jamb on my 2 door Black Diamond.
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I went with 285-75-16
Full details here:
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
39! ok thank you that is very helpful. The Base tires were only recommended at 35 so this is good info
Carolina Jim
Highlands
2021 Bronco 2-door
BD Original Equipment (+55mm backspace/offset)
On-/Off-Road All-Terrain
Size: LT265/70R17 112/109T C
Load Range: C
Serv. Desc: 112/109T
Max Load: 2,470 lbs
Max PSI: 50 lbs
$197 The Grabber A/TX
is General's On-/Off-Road All-Terrain tire developed for the drivers of pickup trucks, work vans and full-size SUVs who need confident traction in a variety of conditions, whether that is on pavement, in dirt, wet conditions and even light snow. The Grabber A/TX is designed to blend rugged durability and on-road civility, in addition to providing light snow traction that meets the tire industry's severe snow service requirements and earns the three-peak mountain snowflake (3PMSF) symbol.
GirthBrooks
Cleveland, ohio
2021 Ford bronco 4 door black diamond
I put KO2s on my black diamond 4 door, size 285 on the stock 17" rims. I don't haul anything other than small hand tools during the week. Dealer put them at 34 when they swapped them for me. Any suggestions on psi??
Headsong
Mine had 42 from the dealer, so a tad higher than door. Temps have dropped, still about 40, but I'll aim to hold that for the winter....
BudgetBronco
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I think anything in the 35ish range is about right. A little lower might give you a softer ride, a little higher will probably give you slightly better MPG.
GirthBrooks
Cleveland, ohio
Awesome thank you for that suggestion!! Gonna try 36 for now
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I run 36 on 285/75.
