what is the Precise dimensions such as length and width about Bronco 8 inch touch screen
Bronco TG offer
briant
united states
broncl sport
I want to customize the screen protector from the Internet, i want the Precise dimensions about bronco 8" touch screen,does somebody can help?
North7
North Texas
SUV
Here are some estimates, they are based on assumptions of the type and size of display screen the Bronco has. Looking at photos of the Bronco displays, as they is all any of us have to go on, the displays appear they may be a standard 16:9 Aspect Ratio or a 16:10 Aspect Ratio. However, it is possible Ford had a custom, non-standard, Aspect Ratio size designed, but unlikely.
The 8" and 12" display size dimensions used are called Nominal Display size. So the next assumptions we have to make are the actual manufacturers dimensions of the display diagonal size. Displays are not always an even number, the 8" display could actually be a 7.9" diagonal size, the 12" display could actually be a 12.1" display size and so on.
As you can see there are a number of variables and unknowns so don't go ordering a screen saver just yet, wait until the actual display dimensions are known. One further twist, the dimensions we are discussing are for the active display area. The actual visible display area is smaller then the overall display dimensions as you have the inactive, black band, boarder area, so the 8" visible display may actually be an 8.3" total display area, the 12" visible display may actually be an 12.3" total display area (see black boarder in Bronco display below). The screen saver may a larger overall dimension to cover this inactive, total display area.
With that background understood, here are the width and height of the 8" and 12" Nominal Diagonal Displays in both an 16: 9 Aspect Ratio and 16: 10 Aspect Ratio.
16:9 Aspect Ratio
8 inch Diagonal Display
Width: 7"
Height: 3.9"
12 inch Diagonal Display
Width: 10.5"
Height: 5.9"
16:10 Aspect Ratio
Width: 6.8"
Height: 4.2"
Width: 10.2"
Height: 6.4"
Ford Bronco what is the  Precise dimensions such as length and width about Bronco 8 inch touch screen FordBronco_4dr_Interior_01 - Copy
