What is your 2022 or 2023 rear cap's engineering part number?
Stick in the Mud
Saco, ME
2023 Bronco Badlands
  • Thread starter
  • Banned
  • #1
I saw a post on here from a 22 owner who had the same engineering part (M2DB-S502G33-AV51MD) for a rear cap as a 2021 MIC2. Am wonderig if anyone has a 22 or 23 with a different part # on their rear cap sticker than M2DB-S502G33-AV51MD ? A bit weird since the production part numbers are different for each MY, so wondering if they are in fact identically manufactured tops.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
My 2022 is almost same EXCEPT the S is an X...
Used to have a 2021, not sure what it said, but having a two door from each of the first MYs now I have noticed my 2021 rear cap (day 1 res) did NOT have anchor bolts high up in roll cage (like all 4dr do I think), it just had 4 bolts/side in the sills.
My 2022 2dr has the 2 high bolts at the top-front of the cap AND all 8 sill bolts...
Anyone with a 2021 2dr that doesn't have the high bolts/did factory just forget to put mine in?
Ducati1098
Not all part numbers are different for each MY. Most stay the same, unless something is changed.
If the 21 and 22 both had the same MIC 2.0 top, they would have the same service part number and engineering number. These numbers wouldn’t change just because one is a year newer.
Ducati1098
If they’ve never been removed, sounds like they forgot them. The top bolts should be there on every one.
Stick in the Mud
Stick in the Mud
Saco, ME
  • Thread starter
  • Banned
  • #5
I wonder if the X is for 2-door (the ones I've seen are 4-door)
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
*You have a 2022 2 door
I have them on my 2022 2 door as well
I did not have them on my 2021 2 door
Seen/read about anyone having them for sure on 2021 *2 door*?
I swear I remember an early top removal tutorial talking about them being specific to the 4 door (MY 2021)...
Stick in the Mud
Stick in the Mud
Saco, ME
  • Thread starter
  • Banned
  • #7
That's what I'm saying; they have different service numbers (sorry, I used the word "production" here), but seem to have the same engineering numbers for 21 and 22.
Ducati1098
If the have the same engineering number, they have the same service part number.
Stick in the Mud
Stick in the Mud
Saco, ME
  • Thread starter
  • Banned
  • #9
If that's the case, then at least a few 22 Bronco owners didn't get a M2DZ-78502G33-CA as they should, but a M2DZ-78502G33-AA.
Ducati1098
Just watched a YouTube video of someone removing their 21 2 door hard top, they had the top bolts still.
Ducati1098
I don’t even see M2DB-S502G33-AV51MD listed in the parts catalog as a engineering number.
It shows M2DB-X502G33-AV51MD for a 2 door
Or M2DB-S502G33-AY51MD for a 4 door.
Stick in the Mud
Stick in the Mud
Saco, ME
Lots of these floating around on 21s, and apparently some 22s.
Ford Bronco What is your 2022 or 2023 rear cap's engineering part number? IMG_7420
Stick in the Mud
Stick in the Mud
Saco, ME
Starting to put the puzzle pieces together a bit now from anecdotal evidence in other threads. It's beginning to look like M2DB-X502G33-AV51MD was a newly manufactured "MIC 2.0" top, while M2DB-S502G33-AV51MD could have been the sticker applied to MIC 1.0 tops that were only re-primed and sprayed in the recall. In other words, if you have M2DB-S502G33-AV51MD, it looks like you might have a repainted MIC 1.0, and if you have a M2DB-X502G33-AV51MD, you might have the actual post-recall manufactured MIC 2.0. This would explain why it's not in the catalog.
Ducati1098
The only difference between S and X is 2 or 4 door according to the catalog.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
where are these stickers located? I have the sound deadending material so wondering if the label is under that material?
I have a fresh 23 - will check after work
