What is your "ala carte" options wishlist?
jayhawkco
Aurora, CO
2006 Nissan Xterra Off Road
360 camera for the off road Bronco.
Only one other vote for it in four pages? I can see there will be a lot of mall crawlers on this forum come next year.
I guess they can use it for parallel parking, I'm super excited to use it for tire placement, 3 point turns, etc.
Pharm351
Paul
1967 Cougar
For me on my Base:
-Washout/rubberized floors
-33 inch wheel/tire option
acetdeucy
daniel
Lincoln Corsair Lexus RX350
- Leather seats
- B&O Sound System
- Ventilated Seats
- 33" Tires on Outer Banks
- 2" Suspension Lift
- Freakin' pull-out freakin' tailgate on the freakin' 2 door.
Yes!!! That's BS that the 2-door doesn't get a pull-out tailgate! I understand it would be shorter than the one on the 4-door, because the under floor space is about 6" less, but at least we wouldn't have to choose from the useless one mounted on the tailgate...
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
4-Door Base Carbonized Gray
*Denotes unavailability for Base trim
- 2.7L and 10spd
- Sasquatch
- Regular Hard Top
- Steel Bumpers (front AND rear)*
- Rock Rails*
- B&O Sound System*
- Heated Seats*
- Remote Start up*
- Baja GOAT mode*
- Auxiliary Switches
Actually doing this little exercise helped me lean even more towards the base model. I can add a front steel bumper from factory and a rear one later on. I can add rock rails, a good sound system, heated seat pads, and a remote start system later on as well. So I get no chance at the Baja GOAT mode which is more of a curiosity of mine than a want.
acetdeucy
daniel
Boxwood Green
New Lime
Skyview Blue
Spingtime Yellow
I’m not too picky, I would take any of those as my A La Carte options.
Realistically... WHITE Roof!
Yes. Yes. Yes.
lobbs611
Kyle
Independence, MO
2D JL Rubicon
The only thing I really care about in the High and Lux packages are the big screen and better stereo. I'd be perfectly content with the Mid package plus those two in my Badlands.
acetdeucy
daniel
4dr Badlands
- High Package
- Tow Package
- Hard Top
I’d considered the Yakima roof rack if there’s a large option. Does anyone think this will be a fine rack to go with or is it just better to go after market? Thinking about the Pioneer Platform by Rhino Rack if or when it’s made for the Bronco. Thoughts?
It's fine. It's inexpensive. It's available, while others will follow over the following 6-months.
Brick Vanderhuge
Pete
NJ
Ford Edge, Custom Softail, Flatside Shovelhead
Primarily the B&O stereo system but leather by itself would be cool.
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
mmm... I suppose maybe its only the front locker that is tied to the Sas... It's clear as mud, no wonder the B&P is taking so long.
Yes, if you want the front locker you must get Sasquatch or a Badlands. I've had lockers and feel that the rear lockers will be plenty for most anything I'll ever do.
OK_Hunter
Greg
Infinity g37
For Wildtrak:
Rock rails - not available?? Aftermarket would probably be better and same cost anyways...
Also, does the lux package come with leather seats included? Seems counterintuitive to call it a lux package if it doesn't come with leather seats - not very luxurious LOL!
Megawatt
JO
Where the asphalt melts in the Summer
Lifted Rubicon usually off-road.
They can always use it to make sure they park centered in their parking spot!
Bwahhh haaa haa. Perfect mall crawler use. You are totally right!
North7
North Texas
SUV
Cloth or Perforated vinyl or leather seats to help those that live in the Hot and HUMID states optional on all trims.
Driver Assist Safety Technology Package that includes all of the Safety items in one package, such as the Pre-Collision, Forward Sensing, Adaptive Cruise and Evasive Steering optional on all trims.
Optional Rear End Gear Ratios available a la carte for all trims.
12" touchscreen available a la carte for all trims.
Universal garage door available a la carte for all trims.
vrtical
Doug
GSMNP, TN
Fords
360 camera shouldnt be tied to lux as its a key piece of the new Bronco marketing for off road capabilities. I get maybe it "works" better on a 12" screen, but an 8" is plenty sufficient enough to utilize it
Cheshire
Steven
FL
That is good to hear about the rear axle. And if I'm reading you correct, the brochure indicates the heavy duty front axle might be an option on the base, outside of the Sasquatch package? That would be a nice a la carte option as well, if not too pricey. As you mentioned, sounds like the locking diff and some other extras would then differentiate the various models. Eager to see this all spelled out in the eventual online ordering guide.
The heavy Dana 210 front axel is available on the Base w/o Sasquatch. But, I would say you do not need the heavy duty front axel unless you get the Sasquatch pkg. Those large, heavy tires and heavy rims will add stress on the axel, especially in high torque, high rpm situations. If you don't have the Sasquatch pkg, the Dana 190s should be plenty. For me, the rear diff locker is a must which is available on all trims except Base.
acetdeucy
daniel
Sure. Even if they think it SHOULD be tied to a bigger screen, you can get a 12" (non-voice), in the High Package.
