- Banned
- #46
I wasn’t going by tire size alone on lift. I know some of what’s involved in a lift such as suspension, blocks ect. I was simply stating that I’d imagine they’re lifting it 2” above factory for 33s. And if warthog is using 37s, I’d imagine they’re lifting 4”. As that’d be enough clearance for the tires. They’re not gonna lift it 1.5” just to accommodate tire size....A lift is much more involved than just tire size including shock/damper height, spring rate, bump stops, and so on. You're going by tire diameter alone, you only gain one half of the difference, or the amount of radius, from the center hub to the ground. So the amount of lift contribution from a 33" to a 35" tire is 1", or .85" based on true tire size.
