What size tire do you hope to run?
What size tire?
  • Total voters
    88
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
I'm running 37x13.5r17 E rated they look ok. I really prefer the 39x15.5r15 on my Bronco though, now that is some seriously good looking amount of sidewall.
Personally, I think you can't beat the look of 15's with 44" super swamper tsl's.
Advertisement
JimmyDean
Louisiana
I agree, but I'll need to upgrade to 1 ton axles, and since the intent would be to use 1 tons from a 2005+, I'll need a minimm of 17" rim to clear the calipers. but even then, 44 boggers on 17s should look good.
Tslater1989
Tyler
Central Michigan
Yep. Much better design on the 05+ super duties. I'd still truss it though.
JimmyDean
Louisiana
will keep that in mind. at this point, im hoping someone T-bones my 06 250 so I can drop teh axles into the bronco and the diesel into the 02 f-150.
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Vehicle Showcase
I picked 33" because I'm assuming those will be an OEM option, with 31-32 being a base level size. 33" with decent ground clearance would take it to places my ZJ and mitsu would never be able to get to as they stand now.
Fosters
Phoenix AZ
2019 Ford F450 2018 Mustang eb premium vert, 2013 Mustang 6A, 2004 mustang gt, 2001 Jeep Cherokee, 2019 Can-Am Maverick Sport X RC
I usually run separate tires on the street vs offroad - much cheaper and better to have good tires for each purpose... also helps I have tire machines and a lift at home. on the XJ it's 32s on the street and 33s offroad right now, going to move to 33/35 if the bronco does end up having an IFS and I'm stuck with my XJ. On my old rubicon I ran 35s on the street/37 trail, though finding a quiet, street thread 35 was a pain in the ass.
rkj__
Ryan
Ontario, Canada
Sierra, Countryman, RZR
That makes some good sense for some usage scenarios.
Even without a lift and tire machine, swaps are super easy if you have the offroad tires on their own second set of wheels. All you need is a jack, and ideally an impact gun.
Fosters
Phoenix AZ
I like the built in disclaimer... lol :D
Dub347sbf
1970 bronco sport 302, 2013 F150 ecoboost 4x4
Rubicon has 285/70/17 which is almost 33 inches. Is that what we guess a top of the line bronco will run? The Sahara runs about a 31 inch tire, 255/70/17.
BONESTOCK
MA
Lightning, Mach 1, Falcon
The only problem with 17" wheels is that there are only a few tires that seem to be made in a load range C when you get to the larger sizes. Most seem to be at least D. And they are not cheap, even thought that seems to now be the most popular off-road wheel size. 15s are nice but you have to have larger brakes to stop a heavier tire/wheel and rig.
You don't have to have larger brakes. Especially if you're not racing it. The larger brakes are for heat management. I can't imagine heat being an issue in a vehicle like the Bronco versus something like a Mustang at the race track.
Advertisement
BuiltRight
Advertisement
