I picked up a 22 Bronco Black Diamond a few months back and have done nothing to it other than add 2" leveling kit and 35s. I haven't had any issues with the truck until a few days ago where I noticed a vibration/humming coming from my front driver side tire/hub. It seems to happen from 30-60MPH randomly and goes away all together when in 4H but when I'm in 2H it's right back. The noise and vibration stays if I let off the gas as I slow down. I'm assuming Ford is still using the terrible IWE design on the Bronco and that is the culprit. Unfortunately I had a 2020 F-150 where both Driver side and Passenger side IWEs failed. The symptoms are very similar to that. I brought it to my local Ford Service center and the tech said my tires are just loud and they don't see any issue but it's definitely a problem. One thing I had done with my F-150 was disconnect the power for the solenoid for IWE to keep the front locked and the issue went away and I've seen guys plug the vacuum lines on F-150s to stop this instead of replacing the IWE. I've also looked at the IWE delete kits. Has anyone experienced these issues with theirs? If this is root then its a real shame Ford hasn't done anything to correct this.
