Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
Good to know. I've never had an airbag deployment. Did you just wanna lay down and take a nap? If so, that might have been a concussion. :ROFLMAO:
I just wanted to GTF outta the truck first! Definitely had a concussion, though.
As I said, I would not recommend it! :ROFLMAO:
OrangeAl
Shannon
I’d like the goat dial to be 4x4 selector switch. Should be able to access goat/drive mode thru steering wheel.
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
The flip down tailgate table. I thought it would be great for tailgate’s and sporting events. Turns out it’s too small to be much more than a drink holder. I’ll probably remove it and replace with a tailgate monunted sub woofer enclosure.
Punchy
Ohio
2023 Bronco
Trail cruise control is reallllllllllly nice between features
I used it for the first time this weekend. I was shocked how much smoother the ride was when I'm not the one trying to maintain the speed between brake and gas. I'm going to use it a lot more going forward.
SierraBronco
2022 Bronco
Right? And no calve cramps! Great for somewhere like Moab where you might be on a trail 4-5 hours and have a bit between features. Not as useful for Sand Hollow 8 rated trails where it’s basically non-stop violence.
timhood
timhood
Tim
Several
I have been trying to figure out how to change this in forscan without any luck.
You would become the GOAT. :ROFLMAO: Maybe if I get the ProCal tuner, I can just set the tire revolutions to 300 instead of 600 or whatever--and just have to remember to set it back before I go back on-road. :)
ManSquatch
Washington, DC
23' Bronco, 17' F250
Brilliant, you would also have a lot less miles on the odometer.
Bschurr
NY
How did you get the actual panel to hold so well with that amount of weight? Mine struggles with a lot less and I even doubled up on the double sided tape. Great job!
If you zoom in on the top edge, I used a few self tapping 1/2” sheet metal screws to securely attach it. Ideally I should have used nutserts but when/if I remove it, they will be covered by the plastic trim and not noticeable. 👍🏼
PurpleBronco2.3
Trevor
Peoria, AZ
2022 Ford Bronco BaseSquatch
Not just one for me but several. Turn assist useless, all those silly driving modes, slippery, mud, snow etc. all I need is 2hi. 4h. and 4l.
I love turn assist and have used it in a few tight turns and it’s a cool party trick on the trails. I use (base) Eco daily for better mpg (since it’s my only vehicle) and use Sport when I want to get a little squirrelly (always switch it back to 2H). Have used slippery and will probably try out the sand mode this winter. Really I just go to it for the throttle response that lacks in Regular and Eco.
AZ_Liberty
2007 Expedition
May I ask why? I use mine every time my front wipers are on, I like to be able to see what's going on directly behind me. I'm sure it has something to do with climate, plenty of rain, road spray and snow here.
1 - I live in Arid-Zona. I vaguely remember rain...
2 - I barely use my rear view mirror, that's why we have side mirrors.
NJ
2024 Bronco Wildtrak. 2011 BMW X5M. 2022 Nissan Pathfinder SL
Yes of course.
I wouldn't make a habit out of using 4-Auto on pavement either, you can feel it bind at times. It's most noticeable when moving around at low speeds in... say... parking lots. Granted it's probably fine for the occasional spirited driving in Sport mode on winding roads, but I wouldn't use it every day.
You can put it in Sport and then back to 2H. That's how I drive mine 99% of the time
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
The spare tire and jack.
At least not yet!
