Wheel color to go with Cactus Gray?!?
FrankenRodz
sheldon
Massachusetts
2022 Base 2 - Door
Am looking into this route. I was going to go rattle can but was curious if you followed through with this
Waiting on the Paint delivery.
Around $100 from Auto Touchup.
2-Spray cans of base and clear, 1-Primer.
I do this a lot at our Hot Rod Shop. Wears like iron, if done correctly… 400 grit light sand, degrease, primer(30 minutes), base (30 minutes), clear (a week). Those are wait times - all in 1-day. All base coats within a few minutes. Let clear set about a week. To guarantee great flow, hit with a heat gun between coats.
I’ll post when done!
8lug
8lug
Has anyone come across a picture of a Cactus Gray + Blue Wheels? I think it might be a stretch.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
I recommend dark wheels on light Broncos, and vice versa. This became apparent when the argent steelies looked like the crap they are on Cactus or White Broncos. Damned if they (same crappy wheels) looked (can’t believe I’m admitting this) pretty good on Antimatter Blue or the Reds. I’ve got nothing against steelies, as I love the Black ones that come with the BD trim level.
Dmorty217
Derek
Venice FL
Camery
Definitely black. Mine is Carb Grey but my brother in laws in cactus with black and it looks sweet
Ford Bronco Wheel color to go with Cactus Gray?!? 3CF40B87-64A3-4DE6-B43D-85E2C90012C7
Ford Bronco Wheel color to go with Cactus Gray?!? E8102998-285C-4933-91D9-762B9E7EA054
broncoj11
Trunks
Oklahoma City
2022 Nissan Frontier Pro 4X
Black, gold, or bronze
The Driving Viking
Northeast
2022 Bronco Sasquatch 2022 Willys Xtreme Recon
As simple as an answer this sounds I really like the stock Sasquatch wheels with Cactus Grey out of everything ive seen. 🌵
Tilzbow
NV
GM Sierra Diesel Pick Up
How about dirty Sasquatch wheels with the beauty rings painted Carbonized Gray?
Ford Bronco Wheel color to go with Cactus Gray?!? FAC270B4-DAD3-4942-8AF5-C756F8A6E2E4
8lug
8lug
The dirt is why I'm leaning away from black wheels... takes a lot to keep em looking good. I like that dirt look!
Tilzbow
NV
The stock wheels are tough to keep clean. I applied ceramic coating (not cheap spray on stuff, the real deal) to my entire rig, including the wheels, and they take some work to clean even after foam canon and pressure washer. It’s still the honeymoon phase so this level a clean won’t last much longer. Anyway thought you might want to see some pics after they‘re cleaned up. Another poster mentioned the stock rings look good with Cactus Gray and I think they’re were spot on so maybe a lighter color could look good. I can’t say I like my carbonized gray better than stock but I do like the fact they‘re different than stock and still look pretty good.
Ford Bronco Wheel color to go with Cactus Gray?!? FDC40B28-CFB6-4C5C-84A8-7F734D3719AF
