Ha, I'm keeping that secret now to hopefully keep my Bronco as unique as possible, but I'll tell you specs if you want. 17X9 6x139.7 -12 offset. Hub centric rings are available for the "toyota size". Honestly, when I bought them, I thought I'd sit on the for 7-8 months, not a year and change.
The wheels are forged, the company that makes them is called DICASTAL (in US and China), but that stamp there can easily confuse some to think he wheels are die cast aluminum (which is what most of the wheels they make are), this has been shared on other threads.Well that just sucks, Made in China & die cast not forged as previously stated. Thanks for the post.
Thank you for clearing that up. That is the problem with so many other threads having been read, leads to some conflicting statements. Happy to know they are forged, not happy they are made in China. They are the style I like however.The wheels are forged, the company that makes them is called DICASTAL (in US and China), but that stamp there can easily confuse some to think he wheels are die cast aluminum (which is what most of the wheels they make are), this has been shared on other threads.
Many aftermarket wheels will go with the standard large bore and supply a spacer to neck down the bore for anything smaller.Did you now that the Toyota trucks and the bronco share the same bolt pattern? So the wheels that you can buy now were meant to fit Toyotas and NOT the Bronco.
Go on right ahead and buy toyota wheels for your bronco.
and this >> Some have said they have contacted wheel Dealers >> Those wheel dealers never told them that the wheel were meant for Toyota trucks and it just happens to fit he Bronco. Toyota and Bronco do NOT share the same hub bore.
it is known...The wheels are forged, the company that makes them is called DICASTAL (in US and China), but that stamp there can easily confuse some to think he wheels are die cast aluminum (which is what most of the wheels they make are), this has been shared on other threads.
First Good Answer I Receivedare the hubs 106.1 mm? BTW most toyota aftermarket wheels are -12 offset.
If the answer above is YES then you have wheel originally made for a Toyota truck. And yes they will fit the bronco.
again no one makes specific wheels for the bronco yet. Given that the bolt pattern ( 6x5.5 / 6x139.7 ) for the Toyota and the bronco/ranger is identical then yes some toyota wheels will work on a bronco via the bolt pattern BUT will require hub centric rings assuming you want the wheels to be hub centric and not lug centric.
TkxFirst Good Answer I Received
yes. for the cheap wheels they will.
Any high quality wheel with NOT use hub-centric adaptors.
Here's a high quality wheel
Tell me more
Are they going to give me a set to use my bronco?They will making wheels for the Bronco as soon as they can get their hands on one >> ttps://titan-7.com/
