Wheel OffSet of Bronco Wildtrak?
oneshot
Dennis
Erlanger Kentucky
F-150
  • Thread starter
  • Banned
  • #1
Does Anyone Know the Factory Wheel Offset On The Wild Track Thanks In Advance
Toccoa
Isuzu Rodeo Sport
Same as Sasquatch. Use the Search.
oneshot
Dennis
Erlanger Kentucky
F-150
  • Thread starter
  • Banned
  • #3
I'd like to see all wheel offset numbers. I would help with aftermarket wheel plans if I go Base. I believe Sasquatch which would include WT and FE is -55
Totally Agree
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
YES....when will we have this data available. Not guesses, from FORD?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
We had actual measurements and images of the numbers stamped into the wheels at the factory.
Wasn't it 55 for the standard wheels and 30 for the Squatch?
::EDIT::
Ford Bronco Wheel OffSet of Bronco Wildtrak? 4931FE6C-DE62-4DFB-9EBA-EA3288A5E713
Ford Bronco Wheel OffSet of Bronco Wildtrak? 3E0F10B5-39BA-4455-9185-A21ACAACFD92
Ford Bronco Wheel OffSet of Bronco Wildtrak? Wheel and Tire
Raptor911
Raptor911
Broadlands, VA
it is NOT -55. -55 is crazy poke.
I think you mean +55.
DUSTYcazOREGON
Craig
::EDIT::
With all the various wheel types and sizes...we need to know for sure before committing to an after market wheel. I know some want to order them already. Thanks for that data.
Raptor911
Raptor911
Broadlands, VA
I don't understand why forum members are wanting to buy wheels for their Bronco early. No one makes wheels for the bronco yet so if you get them now they will not have the correct specs. For example, the hub bore will be wrong.
And if you insist on getting them early then you are getting Toyota wheels.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
And if you get them early then you are getting Toyota wheels.
Or shop for Ranger wheels if you have to get your jimmies out.
Raptor911
Raptor911
Broadlands, VA
The bronco is on the new Ranger platform right? If yes, then current Ranger wheels you can buy now are for the 1st gen rangers.
If the above is correct, then Ranger wheels will not work either or at least not be 100% exact.
DUSTYcazOREGON
Craig
There are some wheels being made that will fit the Bronco. Some have said they have contacted wheel Dealers. It's a rush to get what they want and lack of availability. Told that production issues AND when the first stimulou$ checks came out....there was a run on people buying wheels. Now, short in supply. Just a messenger...
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Good point.
I will say that the steelies look to be exactly the same between what we know about the Bronco and what is currently available on the Ranger...
But either way... I'm holding off before I start shopping for wheels.
Ford Bronco Wheel OffSet of Bronco Wildtrak? Ranger Steel Wheel Black
Ford Bronco Wheel OffSet of Bronco Wildtrak? Ranger Steel Wheel Silver
Raptor911
Raptor911
Broadlands, VA
Did you now that the Toyota trucks and the bronco share the same bolt pattern? So the wheels that you can buy now were meant to fit Toyotas and NOT the Bronco.
Go on right ahead and buy toyota wheels for your bronco.
and this >> Some have said they have contacted wheel Dealers >> Those wheel dealers never told them that the wheel were meant for Toyota trucks and it just happens to fit he Bronco. Toyota and Bronco do NOT share the same hub bore.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
