Wondering if there is an easy way to adjust the speedo if and when you add larger or smaller tires? Is that a dealer fix or a setting?
Any decent tuner for it will, but man would that be an awesome idea for Ford to include it in the factory instruments to change on the fly!Hopefully it is a function in the instrument cluster, but no I would not be shocked if the hear has to be replaced at x tire size.
https://www.tciauto.com/speedometer-gear-calculatorWondering if there is an easy way to adjust the speedo if and when you add larger or smaller tires? Is that a dealer fix or a setting?
No there isn't. Even with ForScan the max tire ratio on a stock Ford F-series is just under 34". Unless Ford starts offering 37's as a factory option, the ability to change those codes will not exist. Even if you attempt to adjust revolutions per mile on the tires, you still will not get it calibrated. Now since the Bronco offers 35's, it's a lock 35's can be added to a non-35 ride and ForScan the system to calibrate the speedo/odometer.Wondering if there is an easy way to adjust the speedo if and when you add larger or smaller tires? Is that a dealer fix or a setting?
News to me. Ive been running 35s on my ‘17 F150 and used Forscan to adjust the speedo/tire size calculation and its been spot on for 2.5yrs.No there isn't. Even with ForScan the max tire ratio on a stock Ford F-series is just under 34". Unless Ford starts offering 37's as a factory option, the ability to change those codes will not exist. Even if you attempt to adjust revolutions per mile on the tires, you still will not get it calibrated. Now since the Bronco offers 35's, it's a lock 35's can be added to a non-35 ride and ForScan the system to calibrate the speedo/odometer.
Since ForScan could in theory be on your laptop and you could use a OBDII adapter you can change that calibration pretty easy, as long as it is within the specs Ford allows.
