112 LBS. for one wheel and tire?Just tried a quote on shipnex. Over a $1000 fuel surcharge!![]()
I ran one for a set of 4 at 80lbs each 24x24x15. got ground for less that $500
shipped from Houston to dc
I put 70 lbs in for the weight but once I put in dimensions for box it changes the weight. Tires are 32” diameter and 10” width so did dimensions of 36x36x12 and that is what populates.112 LBS. for one wheel and tire?
I changed it to 70lbs 35x35x12I put 70 lbs in for the weight but once I put in dimensions for box it changes the weight. Tires are 32” diameter and 10” width so did dimensions of 36x36x12 and that is what populates.
Yes still mounted. You didn’t have any issues with damage doing it that way?I changed it to 70lbs 35x35x12
When I shipped, I didn't ship in a square box, I wrapped the wheels in cardboard. So I was left with round packages. that should bring your dimensions down. You will have to break down a box and wrap it tightly around the the wheel and tires. Im assuming the the tires are mounted to the wheels?
Never!!!!!!Yes still mounted. You didn’t have any issues with damage doing it that way?
