when they install the factory roof rack they use the factory accessory ports, so where would the bracket for the light bar go and how to access the wiring ? Are there photos out there?
I had this thought last night actually - my assumption... and I don't love this... is that they would stack somehow? I imagine light bar ontop of the roof rack. Ford might not make brackets for this, but you could likely make them yourself.when they install the factory roof rack they use the factory accessory ports, so where would the bracket for the light bar go and how to access the wiring ? Are there photos out there?
I installed a 40 inch Rigid off of my roof rack. I made my bracket use 1/4" flat bar and mounted to the top of the roof rack. Had to buy a longer bolt 2 each. I did not use the stock wiring very small compared to the size of the wire that came with the light bar, this was the most work running the new wire. Drilled a hole under the roof rack mounting point for the wiring, sealed it with silicon. The nice thing is the roof right were the wire comes out has a notch in the weather stripping for the wire to lay and not deform the weather stripping.when they install the factory roof rack they use the factory accessory ports, so where would the bracket for the light bar go and how to access the wiring ? Are there photos out there?
Professional question/curiosity: How is that bolt holding the bar to your roof rail locked in? That's not a self tapping screw is it? Is there a washer/nut on the bottom as well????I installed a 40 inch Rigid off of my roof rack. I made my bracket use 1/4" flat bar and mounted to the top of the roof rack. Had to buy a longer bolt 2 each. I did not use the stock wiring very small compared to the size of the wire that came with the light bar, this was the most work running the new wire. Drilled a hole under the roof rack mounting point for the wiring, sealed it with silicon. The nice thing is the roof right were the wire comes out has a notch in the weather stripping for the wire to lay and not deform the weather stripping.
"Remember opinions are like asshole every one has one." Ancient Chinese Proverb.
There is bolt inside the rail that is permanently mounted. The bolt goes through the plastic assembly and into the side rail. So far it still tight if need be can make the bracket longer and use the second bolt.Professional question/curiosity: How is that bolt holding the bar to your roof rail locked in? That's not a self tapping screw is it? Is there a washer/nut on the bottom as well????
There is nut inside the rail that is permanently mounted. The bolt goes through the plastic assembly and into the side rail. So far it still tight if need be can make the bracket longer and use the second bolt.Professional question/curiosity: How is that bolt holding the bar to your roof rail locked in? That's not a self tapping screw is it? Is there a washer/nut on the bottom as well????
This is Ridig that I had on had on hand. Bracket easy to make.Rigid makes a mount, but I think it only works with their light bar.
You had the Rigid mount for the roof rack?This is Ridig that I had on had on hand. Bracket easy to make.
he made his own- but it is good to know rigid makes mounting brackets to go with their lightr bars- I will have to check them outYou had the Rigid mount for the roof rack?
To clarify, the bracket listed above is not designed for my light bar but may have worked. I have Rigid RADIANCE PLUS CURVED 40" WHITE BACKLIGHT.No, I made my own for under $10.00.
4WP website, 2021 Ford Bronco Rigid Industries Roof Rack Mount Kit - 46725 $157.49
Very nice. Is there any whistling or noise from the the light bar at speed?I installed a 40 inch Rigid off of my roof rack. I made my bracket use 1/4" flat bar and mounted to the top of the roof rack. Had to buy a longer bolt 2 each. I did not use the stock wiring very small compared to the size of the wire that came with the light bar, this was the most work running the new wire. Drilled a hole under the roof rack mounting point for the wiring, sealed it with silicon. The nice thing is the roof right were the wire comes out has a notch in the weather stripping for the wire to lay and not deform the weather stripping.
