I used an existing grounding point behind the panels. You will see a bunch of black wires all going to a single bolt. I figured if it was good enough for the other electronics, I could use it also. No issue so far. In other cars I have used frame bolts, seat bolts, you just need a good bare metal connection.What did you ground your amp to? Did you just remove some paint at a hole and run a bolt through?
