Where is jack location for rear ford bronco?
kkurni
WA
Mini Countryman
My rear tire is flat. I need to replace it with spare.
It said it should be in the rear axles.
Any picture to visualize?
604Bronco
British Columbia
www.bronco6g.com
Back cargo area of of the Bronco under the carpet.
Ford Bronco Where is jack location for rear ford bronco? 1642904916949
I think he means the jack point for the rear. It shows you on a sticker on the jack itself.
kkurni
WA
Mini Countryman
Thanks, but what i need is where is the jack point to the vehicle?
For rear wheel, it seems it should be rear axle. But not sure where is the rear axle is.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Call AAA. really
RagnarKon
Bryan
New England
Use the axle tube itself for the rear tires. Should be a spot next to the trailing arm mount where you can put the jack.
If you don't know what the rear axle is... I uhh... yeah... I might have to concur with @kodiakisland
RagnarKon
Bryan
New England
Here... found this for you... a labeled picture.
Red arrow is where the jack goes. Don't pinch the brake line.
Ford Bronco Where is jack location for rear ford bronco? 1642905507677
kkurni
WA
Mini Countryman
Thank you. You safe my life
broncouver
Simon
Vancouver
And in case people are still wondering even after the diagram. Here's an actual picture of the location.
Ford Bronco Where is jack location for rear ford bronco? IMG_1905
