This is exactly what I intend to do. The Bronco will be parked in the garage where it belongs when not in use. I live in Texas, UV kills ;-)Depends on who is doing it. This is one of the things I do on the side, so of course I would love to say "No, professional application only". But in all reality if you have a concept of prepping and painting, an air compressor with enough CFM to spray it, and an area outside that is ok to get some overspray on, you can do it at home and save $.
The kit is more or less $200. You would need a couple of good quality scotchbrite pads and some good 3M tape/masking material.
Tape off all the rubber seals and the entire bottom/front perimeter really well to avoid getting it inside or on rubber seals.
Scotchbrite WELL every single square inch. Clean it off with a quality wax and grease remover (or alcohol). Use a tack cloth and wipe it once dry.
Follow the directions to a "T".
Dry to handle later the same day.
To do it, I charge (on current Jeep tops) $500 for a 2 door and 7-800 for a 4 door with the freedom panels all done as well.
Other places might/probably charge more.
No issues other than IF you put it on, it is a decision that you live with. It is not removable easily or cheaply, and I wouldn't even begin to try.
Aging, it does well. If you do white or black, I've seen no issues with cracking, fading after several years.
I did one for a guy who wanted a House of Kolor blue candy mixed in the tintable version. Looked great for a while. But candy paint does not like UV. I do NOT recommend it.
Using an OD green in a tintable works very well and looks outstanding for those wanting the military look. I've done several.
Cleaning, just regular car wash is fine. I have a long handled medium bristle brush I use to scrub mine when I wash it.
